Re: "Flat monitors."
I don't guess, I know.
I take my mixes to electronic stores and listen on various systems. I go to high end stereo stores and listen. I put it in varous stock car stereos and listen. I goto car shows (every friday nite in the mall parking lot) and listen. Also at the local music store PA stage. (They are kind to me because I buy equip from them). What is implyed by people like where02190 is that unless you have a perfect room with perfect speakers (and mics and converters and amps and pianos, etc) you CAN'T MIX WELL. Where02190, which Fourplay album did you mix so I can go out and buy it. Or did they just track there?? Old Timer [img]images/icons/tongue.gif[/img] |
Seriously, I appreciate these opinions, just a thought here: I mix in my good sounding, more or less average furnitured apartment, no scientifical tests done yet.... My claim is that mixing in an 'average' living room will translate well to the final product being heard in such a room...Anybody?? Andi |
my thoughts on monitoring:
1) consider monitoring a "system" ... it's the coupling of your speakers to the room .. they work in unison with each other to give you "accurate" results, whatever changes you make to one will be affected by the other. Ie. put new monitors into your room, it's gonna sound different obviously ... put a few people, or a couch, or a rug, or some books, or some new gear that's gonna change your monitoring environment as well. 2) you can pretty much mix on any monitor if you know it well enough, sorry newbies experience is the key here 3) a "flat" monitor whilst theoretically possible very rarely behaves "flat" once you put it in a room, unless you mix in an anechoic chamber. IMHO frequency response plots AREN'T the be all and end all, they are good indication of what the speaker is putting into your room but that's about it. 4) to improve your monitoring environment it really is essential to study up a bit on basic acoustics. Auralex have a great article (acoustics 101) that says, in general terms how things work. There's also loads of resources on the net for information on monitor placement. 5) when you are setting up your room make one change at a time and evaluate the success of that change. When it comes to treatment, less is more, don't go over the top on fixing problems you can't explain just my 2 cents [img]images/icons/wink.gif[/img] cheers, marcus |
In reply to "So, vonbleak, how does a sweep from 20 to say 4000 Hz sound on your system now?
Flat? " Yeah, pretty much, i use the new mackie HR624's which are fairly flat, so from there end its pretty good. My room is not perfect so i cant say i monitor in a totally flat environment but im getting to that! [img]images/icons/grin.gif[/img] (Room treatment is on the agenda)
Audio Engineer/Musician/Producer |
Also, we must take into account that the human ear does not have a flat frequency response, look up the 'Fletcher Munson Graph" So reliying purely on the response graph of monitors is never going to be %100 accurate, but we do our best! [img]images/icons/grin.gif[/img]
#16
It is so important to listen to your mixes on as many different systems and environments as possible. I can send to the green room and listen from down the hall, have a crappy old sony blaster, a single mono speaker behind a chair...plus I too go to stereo stores and make 'em play discs for me, all the while cranking up the bass and treble, and any other knobs that can be twisted to the right...cuz when is the last time you saw Joe or Jane average turn anything to the left!!!!! My "mix blessing method" is to listen in my truck, windows down, in traffic. If it's all still there amongst all that distraction I know I got it right. Occaisional "who's that" comments from other cars is a bonus. Quote:
#17
I bought the Mackie 824's due to the recent reviews pointing them out ot be the flatest monitors to come out in quite a while. Even compared to some genelecs.
#18
If the room has say a node at 140hz, changing speakers does nothing to correct this. Eqing the monitors does not correct this. Eqing the room, i.e. acoustically treating the room to reduce or eliminate the node does.
Very True. Also, I recently learned something about activating a room. My room is terrible, I put a 400$ roominator kit in and still have a noticeable problem. It was suggested to me by a well known producer, that each room has an activation threshold and that if you keep your volume under that threshold, you can keep the room out of the mix even further. I don't completely understand it, but it is work. There is a definite advantage to mixing at lower volumes. |
#19
A speaker system responds to it's environment. If the environment has inherant characteristics of certain frequencies, these frequencies will be present in the response of the system in this particular environment. Thus the importance of room treatment. If the room has say a node at 140hz, changing speakers does nothing to correct this. Eqing the monitors does not correct this. Eqing the room, i.e. acoustically treating the room to reduce or eliminate the node does.
Personal preferences are the biggest factor in choosing monitor systems. If you are comfortable with them and you are getting good results, no matter what the system, then it is right for you. This is probably the oldest debate in the industry, and one that has nor never will have one clear defined answer. What works for you is what is best for you. Finding that is your own personal journey. Obviously the advise of others is a great starting place, but ultimately, only you can decide what works for you. |
#20
When my table loses its luster, I'll probably try to implement a setup that uses only small racks on rolling stands that I slide over as I need them. |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
Entering sleep mode causes loud "bump" in monitors | tobbenos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-25-2008 04:29 PM |
Monitors... "DS90" (Roland) VERSUS "MSP5" (Yamaha) | Renan | General Discussion | 2 | 12-26-2002 03:36 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
