Waves SSL issue
Is anyone having any problems with the Waves SSL bundle after installing Pro Tools update 7.3.1cs4?
I'm having very strange display problems with just the SSL stuff. Sometimes with putting a SSL plug in on a track, everything just freezes and locks up. I also just installed the URS CPS pro and thought that might be it, but after uninstalling that I still have problems. Anyone else? Or is it just me. Any ideas? |
Re: Waves SSL issue
Try reinstalling the SSL plug after the URS Channel Strip Pro.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: Waves SSL issue
in your display properties,in color quality, are you on highest 32 bit?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
Re: Waves SSL issue
I tried to reinstall the SSL with no luck.
I will check on the display settings. Thanks, Phil |
Re: Waves SSL issue
Shane
Re: Waves SSL issue
How do you "roll back" the ilok driver? I did update the ilok driver because I was getting an error when launching Pro Tools. Something like TPk... error, update driver.
I'm not at that computer right now so all of this is from memory. I have been using the SSL bundle for the past year with great results. They are my "go-to" plug ins. It must have been something I've done in the past few days to cause these problems. |
Re: Waves SSL issue
Go to device manager/dongles/usbilokdriver/drivertab/rollbackdriver
brandy |
Re: Waves SSL issue
thanks. I'll give that a shot.
Re: Waves SSL issue
still no luck..
anymore ideas? |
Re: Waves SSL issue
Bumping this back up with some more info:
What else has changed on your system recently? I just updated Pro Tools with the cs4 patch. I had been using ver. 7.3.1 I also installed a demo of the URS CSP on my system, which required me to update the ilok driver. I also updated my display driver after I started having trouble, thought that might help. Does this happen on a specific session/or on all sessions (including a blank session)? It happens when you open the plug in to look at the settings. It will happen in all sessions, even blank ones. If you open a session that already had the SSL plugs on it. It will play as long as you do not click on the plugin to change the settings. What is the buffer size of your session? I usually keep my buffer at 128, but this happens at all settings. What is the sample rate of your session? 44.1k Does this happen with all the components - Eq Channel and Comp? Yes Anyone have problems like this? And if so...how did you fix it. I think it's something related to my graphics card, an ASUS/NVidia GeForce 7600 GS. (ASUS EN7600GS SILENT/HTD/256M GeForce 7600GS 256MB 128-bit GDDR2 PCI Express x16 SLI Supported Video Card ) But like I said, I've used this with no problems since Jan. 2007. |
Issue with Waves v9 in PT10HD | dannymeltzer | RTAS & TDM Plug-ins | 11 | 04-21-2015 12:18 AM |
Waves Authorization issue | Brad Galvin | VENUE Live Sound Systems | 0 | 08-09-2011 11:52 AM |
Waves issue | Frank of Denmark | Pro Tools TDM Systems (Mac) | 0 | 08-25-2009 07:25 AM |
one waves issue sorted, now for the other...... | crizdee | Pro Tools TDM Systems (Mac) | 4 | 03-30-2007 05:13 PM |
Does anyone else have this Waves issue? | Mark Wheaton | Pro Tools TDM Systems (Mac) | 3 | 05-26-2006 03:20 PM |
