Repeatable Audiosuite crash with Pitch N Time, can somebody test ?
Repeatable crash, after a difficult day with 5 crashes doing editing and pitching i’ve set aside some time to try and work out what is going on , please test if you can.
New session, i was 44.1 24bit interleaved 12.4 10.9.5 HDX 1 Create mono track, don’t rename 2 Consolidate a few bars of silence so you have an empty region , now called Audio 1_01 3 With that region selected, commit selected tracks, -options - don’t consolidate clips, volume or pan, copy sends , group assignments , insert after selected track, Do Nothing, offline So you now have original and a track called Audio 1.cm, with a region on it called Audio 1-cm-01 4 Save at this point if you want to retest 5 Pitch N Time pro audiosuite, (i’m on 3,0.2) 1 semi up, process Crash every time here, anyone else confirm? if so i’ll tell Serato I got a feeling i’ve seen this before with another plugin previously , maybe it’s something to do with the name it gives it when it’s processed. I can’t test this on 12.5 as it was such a disaster for me with VI’s i’m not going back! |
Re: Repeatable Audiosuite crash with Pitch N Time, can somebody test ?
+1
I'm suffering the same issue.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Make a video
Pitch'n'Time needs an update.
It's been crashing PT for me for a while now, every time I hit render.
Serato were able to reproduce this crash fyi, will see what happens.
Access violation here but no crash. However, it happily PNT'd the original track at Step 5, just not the committed one.
12.4 Windows 10
"Modern manufactured music is like art they sell at a furniture store." http://www.weddingmusicproject.com/ http://www.weddingmusicproject.com/w...music-samples/ http://stevemillikan.com/ |
+1
PT 12.4, used as an audiosuite, I'll get a crash 60% of the time. I'm done using it. Waves Soundshifter with Commit works like a charm and sounds better |
yes - now with PT 12.7
Not sure if this is related, however AudioSuite does not render Avid's own SoundReplacer plug in 12.7. Works in 12.6.1.
Not a crash ... just no output. Seems like 12.7 has AudioSuite issues ...
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
Repeatable Crash in 12.4HD | gonzolagonda | Pro Tools 12 | 1 | 01-25-2016 04:44 AM |
PT 10 repeatable crash | T-Low | Pro Tools 10 | 17 | 10-09-2014 12:06 PM |
AudioSuite handle bug in Pitch & Time | rhumphries | Post - Surround - Video | 1 | 10-30-2011 07:12 PM |
Audiosuite Pitch 'n' Time on an Avid? | reichman | Post - Surround - Video | 1 | 01-06-2010 06:26 PM |
Repeatable crash | Submersible | Pro Tools TDM Systems (Mac) | 0 | 05-12-2003 02:51 PM |
