Workspace: Search 'rain' get 'train'
So I search for Rain and I'm presented with Train as well as Rain samples. Why? This is pretty annoying.
Thanks for all the help! |
Re: Workspace: Search 'rain' get 'train'
What happens if you go 'advanced search' an put rain in quotes and search for, or exclude, certain specific file types?
It's probably finding any file with rain in the name, like train, training, drain, etc.
Yes this is exactly what's happening. Why? Why would it do this? This is of little use to someone searching for sound fx. It's actually counter productive lol.
I don't see an advanced search function in the workspace. Only the hamburger button which gives me more options but even if I have two lines one for "Contains Rain" and another for "Doesn't Contain Train" it still show Trains
What happens if you search train instead?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
as expected, you get train samples. The issue is that I don't want train samples...I want rain samples and only rain samples.
This is perfectly normal behaviour. Also happens when you search for wind. It will return window as well. This is useful otherwise you wouldn't find records labeled as "windows" when typing "window" into the search.
Same in Soundminer and other advanced library tools. Not sure if this works in PT12 as I don't use it but in soundminer if you want to find an exact match you just type ' "rain" ' into the search. That gives you only records that contain the exact spelling and not train and all other words that contain the string "rain". Or you type rain -train or wind -window. Or you can exclude a group of words using (). Example: wind(gusty, blowing) -window. The comma being a logical OR and the minus a logical NOT. So the result will give you records that must contain wind and either gusty or blowing but not window. It saves you a great amount of time learning how to use boolean search options... But again: I don't know if this works in PT12.... Hope this helps. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 01-02-2017 at 03:56 AM. |
I was under the impression "Rain" would be enough but the rain -train works beautifully. I appreciate your help very much. Jeremy |
F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Workspace crashes on every search | Ale | Post - Surround - Video | 12 | 11-16-2021 11:56 PM |
Workspace search bug | veet | Pro Tools 12 | 1 | 03-07-2016 12:28 AM |
Workspace Search Errors | Peter Miller | Pro Tools TDM Systems (Mac) | 2 | 09-10-2010 01:50 PM |
PT8 Search in Workspace bug | matt connolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-03-2009 07:44 PM |
workspace search problem | markabaus | Pro Tools TDM Systems (Mac) | 1 | 08-25-2006 11:09 AM |
