Drive Maintenance
Just looking at apps for drive maintenance...is there one that clashes with PT 7.3.1 cs? Is there one that works exceptionally well? I was looking at Drive Genius, but can't see that it has a defragmenting feature. Any recommendations would be appreciated.
Thanks Powerbook G4 1.67 ghz, 80G/1Gig Ram/160GB LaCie FW drive |
Re: Drive Maintenance
evry1 seems to like disk warrior
Mac Studio M1 Max, 32gb, 2024.3u, HDNTB, Aurora 16n LT2HD, 14.3.0 |
No defragging is necessary in OSX.
Disk Warrior is great when your disk is in trouble but other than that just run your regular maintenance routines - repair permissions, CRON scripts, clean caches. I always use fsck -fy first if there's a sign of disk trouble - then I might go to Disk Warrior. peace
MacBook Pro DuoCore 17" 2.16Ghz • OSX 10.4.9 •*2Gb RAM • MBox 2 Pro • ProTools 7.3.1cs3 • FW 800 w/ Express Card |
Do a search for "Cocktail" or "Macjanitor".
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
HI,
the best safest and fastest way to "defrag" is backing up, deleting, copy back. Use Carbon Copy Cloner for this to clone ANY disk partion. It`s a GUI to the OS X built in "ditto" backup programm. CCC will eventually become obsolete when OSX 10.5 introduces Timemachine. and as the OLD and proved Unix saying goes: if a disk/partition is half full it`s full. regs
last: PT11.3.1 |
The utilities Park mentioned can run them for you. You can also run them from the Terminal application: Open Terminal - you will see a command prompt -type sudo periodic daily Hit Return You will be asked for your administrative password - enter it Hit Retun The daily CRON script takes a matter of seconds to run You will be returned to the command prompt - type sudo periodic weekly Hit Return You won't be asked for your password this time - you are already logged in as an administrator This one will take a while to run - maybe 2 or 3 minutes When it is done you will be returned to the command prompt again - type sudo periodic monthly Hit Return This one runs very fast When the command prompt reappears quit Terminal That's it. You have run your CRON scripts. If you do this and repair your permissions before you install software and after you install software that is all the regular maintenance your computer should need. fsck -fy and Disk Warrior are for when your hard disk is sick. Which on a Mac isn't very often in my experience, although I have had to use them both. peace
what exactly does CRON clean up?
Mac Pro 2x 3.0 ghz Quad /5 gB Pt LE 7.4 cs 2 002R MPT G4 Ti-book 1 ghz/1 gb 10.4.6 Pt le 7.3 cs 2 Mbox |
Cron is simply a schedule.
From the Apple web site: Mac OS X performs background maintenance tasks at certain times if the computer is not in sleep mode. If your computer is shut down or in sleep at the designated times, the maintenance does not occur. In that case, you may want or need to run these manually. Mac OS X periodically runs background tasks that, in part, remove system files that are no longer needed. This includes purging older information from log files or deleting certain temporary items. These tasks do not run if the computer is shut down or in sleep mode. If the tasks do not run, it is possible that certain log files (such as system.log) may become very large. These tasks are scheduled for 03:15 to 05:30 in your computer's local time zone. This is described further in "Mac OS X: Unexplained Disk Activity Produced by "find" Process". If your computer is normally shut down at night, you may choose to force the process to start manually. How to force maintenance tasks You have two options: Use a third-party application or Terminal. Use a third-party application Some third-party applications may allow you to run these tasks whenever you wish. Four examples include: Macaroni by Thomas Harrington Mac Janitor by Brian R. Hill CronMaster by Dan Klein weRclean by Parental Advisory You can search for these or other solutions at VersionTracker (http://www.versiontracker.com/). Also, check this out: http://www.apple.com/downloads/macos...intenance.html
thanks park. I generally leave my compuuter on 24/7, so these processes run daily?
drive maintenance | viaspiaggia | Post - Surround - Video | 10 | 10-12-2012 11:58 AM |
Drive Maintenance Software | neil_mcdermott | Pro Tools TDM Systems (Mac) | 10 | 01-18-2004 09:37 AM |
firewire drive maintenance | 372cat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-18-2002 03:59 AM |
Wiping the system drive for maintenance | guitarrob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-10-2002 09:14 AM |
drive maintenance | rocknpop | Pro Tools TDM Systems (Mac) | 0 | 03-21-2001 11:59 PM |
