Old 06-17-2007, 02:14 PM
JonesH JonesH is offline
Default Distortion removal
Well, this has surely been discussed befpre, but perhaps it's time for an update (also, I found zlich searching ).
What are the options, methods and preferred plugins for removing distortion and clipping?
What are your methods (except for re-recording...)?
I just wanna do engineering...
(as opposed to make music :/ )
Old 06-17-2007, 06:30 PM
M.Brane M.Brane is offline
Default Re: Distortion removal
Recording is a lot like grilling a steak: you can always throw it back on for a few minutes if it's too raw, but once it's overdone you're screwed.
That's why I always order medium-rare.
Old 06-19-2007, 08:40 AM
I'm a vegetarian
But anyhoo, what are your methods when a client shows up and you gotta reduce distortion in the material?
Some people use the anti-crackle plugins featured in i.e. Waves X-series or WaveArts Master Restoration suite. I find that they sometimes help ,but lack real capacity for change.
Seeing as how distorted and clipped material is a common problem, surely experienced people like the ones on this board must have ways to deal?
Old 06-19-2007, 09:16 AM
Slim Shady Slim Shady is offline
Well, start by saying "there's nothing I can do to fix that" and then maybe run all the tracks through a sans-amp plug-in and tell them you're going for a "sound" ... but generally speaking distored material is unusable material, you can't 'undo' distortion, especially the digital clipping kind.
If you seriously have lots of clients coming to you with distorted recordings, maybe you should think about hosting a little 'recording techniques' class for them so they can learn how to make recordings they can actually use. Distorted and clipped material definitely should not be a 'common problem' - it's not one that I've ever run into with any of my clients, and I have clients of all different levels and experience, and even the ones who can barely remember how to launch PT at least know that seeing the red clipping light in the meters means re-doing the take.
Old 06-19-2007, 12:54 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Tell your clients, "Red lights bad". Have then drop their levels 20 db and you will be fine.
You can't add back audio to a flat top.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-19-2007, 04:48 PM
Yeah most of the restoration/noise removal plugs are for removing ambient noise from an otherwise clean recording not repairing clipped peaks on waveforms. Not really anything you can do about that other than try to hide it in the mix somehow. Tough to do with clipping that is clearly audible, and if it's on multiple tracks the cumulative effects are even worse.
Old 02-06-2020, 10:43 PM
Simon Reich's Avatar
Simon Reich Simon Reich is offline
Well, I guess because this thread is quite a few years old, I need to update the answer. i just used Izotope De Click & it worked an absolute charm. Repaired the sheared of WAV files & playing with the threshold & make up gain settings made it completely disappear.
The burnt steak can now be put back on the grill & made into medium rare
Simon Reich
Model : ASUS All Series ASUS MB Mainboard
ASUS Z97-A
BIOS : AMI (OEM) 0902 05/08/2014
Intel vPro : 9.01.01.1000
Total Memory : 16GB DIMM DDR3
Processor : Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz (4C 3.9GHz, 3.9GHz IMC, 4x 256kB L2, 6MB L3)
Operating System
Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Vocal Removal? qpeck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-16-2007 06:58 PM
removal of protools 6.4? MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-24-2006 05:53 AM
Removal of old version Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-27-2005 07:23 PM
Click removal soundeziner Post - Surround - Video 3 12-02-2004 12:33 PM
OT Removal of Mac OS 10.1.5 Stephen Bond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-30-2003 05:00 AM
