Replacement Parts for Command8
Does anyone know whether Avid sells repair parts for the Command8 to consumers? The on/off switch on my unit broke yesterday (the plastic part). I went to the Avid site to try to find how to order a part, all I found was a list of authorized repair centers (none in my city). Emailed the nearest one and it came back undeliverable.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Re: Replacement Parts for Command8
Update: I was able to remove the broken switch by first removing the bottom cover of the Command8. The 4 wires attached to the switch were removed with a pair of needle nose pliers. Connected via spade terminals, not soldered. I temporarily bypassed the switch by connecting the red to red, blue to blue. Plugged the power supply connector back in and I am back in business. The switch itself has a manufacturer name and model #, so I should be able to find one locally.
But if anyone knows whether Avid sells repair parts, I would still like to know.
I'm pretty sure you will still need to go through a Service Center for parts.
Just contact a few you should get through to one.
URBAN MUSIC- (Hip Hop and R&B) |
Update #2: Went to a local electronics parts store this afternoon and found a similar, but not exact on/off switch. The original was 4 poles, the new one is 6 poles (same size). With a multimeter I figured out which were the pairs, and connected the blue and red wires accordingly. Total cost $3.95.
Could be please give a little more detail on what to do from here, red wire to red what? and blue wire to blue what? Thank you!!!! |
replacement parts for mbox 2 pro | jrob70611 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-22-2012 01:11 PM |
i move some parts then parts are unmuted... | montreal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 05-08-2010 05:56 AM |
Committing midi parts to audio. All parts ahead of bar line | sad1robot | Pro Tools TDM Systems (Mac) | 2 | 04-25-2010 01:09 AM |
Command8 as a HUI | eugenometica | ProControl, Control|24, Command|8 | 4 | 02-26-2006 07:08 PM |
Sennheiser MD421 replacement parts? | bwherry | General Discussion | 0 | 10-11-2004 10:26 AM |
