Old 04-19-2009, 04:59 PM
smetaxas smetaxas is offline
Default Insufficient resources?
I have a mix that keeps taking Soundtoys Pitchblender & telling me it can't load due to insufficient resources. I have plenty of TDM slots & voices still available. What could be causing this? I also just got a DAE error #1. Anybody??
I'm running a Quad Core system with HD3 accell PCI built by Terra Digital.
Old 04-19-2009, 08:41 PM
x9blade x9blade is offline
Default Re: Insufficient resources?
i've always had problems with soundtoys tdm on my pc mostly graphic problems
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 04-20-2009, 02:28 AM
eddierodriguez eddierodriguez is offline
you´re on pt8?
it´s a bug, hopefully it´ll be sorted out on cs3.
Old 04-20-2009, 05:13 AM
what exactly is the bug you speak of?
Old 04-21-2009, 08:06 AM
I'm on the latest PT8 version. I just got the same thing with Digi Med Delay so it must not be a Soundtoys only problem. I also seem to get error #1 messages too.
Old 04-21-2009, 08:12 AM
DigiTechSupt's Avatar
Which version of Soundtoys do you have installed? How many chips are available on each card and which chips are in use (allocated, either partially or wholely)? There are 9 chips on each card - if you can let me know the percentage of each chip on each card that's allocated, it will help identify the problem.
Alternately you can send me a copy of the session file to: vi [at] digidesign [dot] com. Include your plug-in version list (you can generate one using the Tech Support Utility from the General Troubleshooting thread) as well as you complete system configuration info.
Eddierodriguez - what were you told and by whom about this being a bug and it getting sorted in cs3? I'm not seeing anything specific to this in the queue for cs3, so I'm wondering where you got your information.
Avid Audio Tech Support
Support FAQ
Insufficient System Resources kazanz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-09-2010 01:53 PM
Insufficient System Resources? Steve@ZooWest Pro Tools TDM Systems (Mac) 1 11-09-2006 07:16 AM
Insufficient resources -on a G5? Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-26-2006 03:26 PM
Insufficient resources without changing anything? e-cue Pro Tools TDM Systems (Mac) 13 05-13-2006 10:35 AM
5.1 Showing insufficient system resources JLEpperson Pro Tools TDM Systems (Mac) 0 06-05-2001 04:40 PM
