Old 07-28-2005, 10:41 AM
headclouds headclouds is offline
Default asio driver problems
i recently started using protools on my pc (win XP,3.2 ghz, 1g of memory, HT is on but never had a protools issue with it so i never disalbed it) but i still have my cubase, reason 2.5 and sound forge still installed and use for my old projects. problem is that once i open one program and then try to use another.. theres a driver failure and i have to reboot my puter so that i cant use the 002 with either of the other programs. before protools i just used the motu 828 sound card and never a problem with any program. now i do!
Old 07-29-2005, 10:12 AM
WaxTrax! WaxTrax! is offline
Default Re: asio driver problems
I believe the Digi ASIO driver is single-client only, which means that you can only use it with one program at a time, which really sucks. Even a cheap $50 SB Audigy 1 card comes with a multi-client capable ASIO driver!
That's why in my system, I use my Mbox for ProTools, and my SB Audigy 2 ZS for everything else (like Cubase, Sonar, etc). The 2ZS card has a multi-client ASIO driver, and it will record at 24/96, and play back at 24/192. Not bad at all for $89
Mbox 2 ASIO driver problems BunX FireWire & USB Audio Interfaces (Win) 1 08-25-2013 07:19 AM
ASIO Driver Problems with Sonar 8.0 and FL 8 scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2009 03:43 PM
Asio driver problems with 002 Pro tools 7 with SP2 inka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-03-2007 08:01 PM
ASIO driver problems - CPU straight to 100% Groovr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-21-2007 10:41 PM
Asio driver problems Full Clip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-08-2003 09:35 AM
