Old 01-24-2018, 12:01 PM
EddieJones's Avatar
Default Pro Tools 18.1 Softkeys
Here's a link to a patch that installs the PT 18.1 Softkeys onto the Master Module if you are updating. S6 v3.8 in a few weeks will have these but in the meantime this should get you up and running. Just run it on the Master Module after logging in as Admin.
S6 updater for PT18.1 Softkeys
Old 01-25-2018, 06:32 AM
probob probob is offline
Default Re: Pro Tools 18.1 Softkeys
What about S6 version 3.6?
thank you
Old 01-25-2018, 07:01 AM
EddieJones's Avatar
Yes that will work for previous S6 versions too.
Old 01-30-2018, 08:17 AM
kava kava is offline
Hi
Thank you for the patch,
I use a lot of custom softkeys including custom graphics, will they load after installing the patch?
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 01-30-2018, 09:04 AM
EddieJones's Avatar
After you have installed the patch, load in you custom Appset.
  • Connect to PT 18 (Focus the Workstation and make sure PT 18 default soft keys are loaded)
  • Go to Settings – Soft Key Editor page in MTMApp
  • Press Load menu button on bottom of screen
  • Go to C:\ProgramData\Avid\S6\Appsets (the dialog should default to this location, unless they already loaded from somewhere else)
  • Find older PT 12 appset (They will see both Mac and PC there, and need to select the right OS version to get their custom soft keys)
  • Load it
Old 01-31-2018, 04:02 AM
Hi Eddie,
many thanks, it worked.
16 Softkeys not active Moviesound Avid S1, S3, Dock and Control App 54 10-23-2017 02:56 PM
Softkeys are binded to macos tbov Artist Series 0 10-13-2016 08:06 AM
SoftKeys customizing - XML OvD Avid S1, S3, Dock and Control App 2 08-17-2016 02:32 AM
Copy softkeys in EuControl ? HansH Artist Series 7 05-07-2012 01:35 PM
C|24 and PTHD softkeys fakir_cz ICON & C|24 4 12-01-2011 06:54 PM
