CONVERT WAVE OR OTHER AUDIO FILES TO MIDI???
Hi i seen a post a little while back that told of a program that converts audio files to midi. the post was answered by a guy from bfd i believe. it is used primarily to covert drumtracks that are saved in an audio format to midi to be edited ect. i cannot locate the post after some considerable searching. (i should have subscribed to it) if someone could name the program for me i would appreciate it.
thanks,
www.niagararocks.com |
Re: CONVERT WAVE OR OTHER AUDIO FILES TO MIDI???
any others?
A company called Celemony makes a piece of software called Melodyne.
I own Melodyne Studio v3, and I love it.
it just so happens that i have melodyne Cre8. i tried to export a drum track as midi but it is not recognized as a midi file by protools. i can play it and it sound like piano notes. maybe i'm doing something wrong, or Cre8 doesn't do what i'm hoping for. any direction would be much appreciated. i'm hoping to redo all my drum tracks with ezdrummer when it comes out this month. any drum tracks i have have been made with audio not midi. The kicker is that i have no experience with midi as of yet.
If you tell me what you're trying to do with Pro Tools and Cre8 and how you're doing it, I might be able to help you.
when i exported the file from melodyne i was expecting some sort of grid like when you pencil the notes in in protools. when i tried to import what i thought was a midi file pro tools didn't recognize the file i got from melodyne. basically i have some drum tracks in 2 channel wave format that were made with a roland drum set. those patches from the machine are long gone and the drummer is only good for a couple of tracks a year. so my best bet is to try and convert the wave audio to midi. i hope in turn i can use that to trigger the ezdrummer program which is midi based. this is all in a quest to polish some old tunes with better sounds. i really don't know much about midi other than it works like triggers. i guess what i'm getting at is can i use melodyne to create a midi file from my wave format drumtracks so i can load them into easy drummer and have stellar sounds. when i watched the easy drummer demo the midi files that were loaded looked like the grid that you would fill in with the pencil tool. it would be great if melodyne could map the drumtrack like that. i tried to import the above mentioned file to protools as a test to see if i had the right conversion. when i click on the file by itself it plays with windows media player and sounds like a piano. when i check its properties it says its midi. it would not import at all to protools.
thanks
Iv been trying to sort this out for the last 2 days with a kick drum, turning it into a midi track. I have MelodyneUno which doesnt convert to MIDI i think he only one that does is Melodyne 3.
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
How do I convert mac SD2 files to wave files for pc? | Cranky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-23-2007 11:14 AM |
Convert midi files to audio with Gigasampler sound | wonderfall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-03-2003 09:11 AM |
How do I convert MG files into Wave or SD II? | mix2much | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-18-2001 10:40 AM |
WAVE CONVERT PRO & Pro Tools to-CD files | Bonedawg | Digidesign Hardware & Software | 1 | 06-29-1999 11:31 AM |
