Old 09-01-2002, 11:00 AM
7k 7k is offline
Default Plug In Button dead
For over a year I have used the Plug in button to close the current plug in window. Now it doesn't work. Digi even sent me another unit to fix the problem. (this is a newer unit, not the year old one.)
The replacement still does the same thing. Is it a possibility that in upgrading to the 5.3.1r2 - (Or whatever that last revision is) could be the problem? I only updated cause they said it FIXED issues with C24.
Any thoughts?
The light never comes on and the button is dead, although testing it with the self test seems to work, telling me that it is maybe a software glitch.
Thanks!
Paul
Paul Dexter
7k' Productions
7kproductions.com
Old 09-02-2002, 08:02 AM
Nash BBQ Nash BBQ is offline
Default Re: Plug In Button dead
Mine is about 3 months old and I have a similar problem...
If I open a Plugin when I'm on the Mix screen, then I switch to the Edit screen, the Plugin button won't close the Plugin window when I'm on the Edit screen.
I haven't been loosing sleep over it but I'll just throw that out there.
Good Luck.
Reid C. Scelza
Barbecue Productions
"where taste and music come together."
Old 09-04-2002, 04:51 PM
Jan Folkson Jan Folkson is offline
I'm seeing it too. The button will open the plug but not close it. Just installed the r2 upgrade with no improvement.
- Jan Folkson
www.janfolkson.com
Dead Talkback on PC - button now flashes when held audiomark ProControl, Control|24, Command|8 2 12-14-2007 01:17 PM
SYNC I/O Dead. Only amber ring around power button Mt.Everest Pro Tools TDM Systems (Mac) 1 10-17-2006 10:24 AM
C24 Bug - Window Button / Plug & Pan hanz marathon ICON & C|24 1 02-06-2005 10:04 AM
Why must Digidesign's plug-ins be dead ends? Lee Blaske Pro Tools TDM Systems (Mac) 43 05-21-2004 02:42 AM
Plug-in Button lights up iamstudios ProControl, Control|24, Command|8 0 06-29-2001 01:55 AM
