888/16 AES Test
Is there a way to set the 888 to receive AES when it first powers on?
I have a 192 sending 8 channels of AES out directly to the 888/16 and I'm not seeing anything. The 888 is showing Sync Mode as "Internal" and "Analog" on the 1-8 channels. I thought there was a way to power these up to receive AES? This is not connected as a legacy device, since the 16bit 888 don't work that way.
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: 888/16 AES Test
888/16 will need a computer connected to it, you need an 888/24 if you want to use it as a standalone converter.
See this thread for a little more info: http://duc.digidesign.com/showthread.php?t=230825 |
Another PTLE Stress Test- "DaVerb Bounce Test" | BioFeedback | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-11-2004 05:48 AM |
digi 001 failed test 22 shared memory test | the originalman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-14-2003 07:31 AM |
Test 55 and test 123 in Digitest | livearts | Pro Tools TDM Systems (Mac) | 1 | 10-11-2001 08:36 AM |
This is a test | stuart newman | Pro Tools TDM Systems (Mac) | 2 | 02-07-2001 04:56 PM |
Forum Broken test 1,2, test | MacDaddy WGAR | Pro Tools TDM Systems (Mac) | 1 | 10-16-2000 06:56 PM |
