Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 09-23-2020, 04:32 AM
OllieKas OllieKas is offline
Default M Audio Fast track head phone port
Hello all,
I own a fast track ultra which has two headphone ports. Port 2 is not responding. I was powering it via USB. To ensure that it is not a wall power issue, I recently purchased a wall power adapter with the specified specs and that hasn't helped.
Any ideas
Old 09-23-2020, 03:00 PM
Top Jimmy's Avatar
Default Re: M Audio Fast track head phone port
The two front-panel headphone outputs are assigned to outputs 1/2 and 3/4, respectively as stated in the manual.
If you want something to come out of the second headphone jack, you either route an output from the DAW to 3/4, or you use the Fast Track mixer built into the driver to route the 1/2 output to 3/4.
James Cadwallader
Old 09-25-2020, 12:16 AM
Dear Jimmy,
Thanks or your response it was insightful. How can I do the routing on the built in mixer and indeed from the DAW? Im using Qbase5 and my attempts have not yielded for both suggested solutions. Im probably missing "the how". I was able to shift the output from 1/2 to 3/4 on the DAW but it disables 1/2. Thanks
Old 09-25-2020, 12:29 AM
Top Jimmy's Avatar
You either route the output in Cuebase to both 1-2 and 3-4 at the same time, or you use the M-Audio mixer app to route the 1-2 software output to both the 1-2 and 3-4 hardware outputs.
James Cadwallader
Old 09-25-2020, 07:08 AM
Hello Jimmy,
Thank you so much!
I managed to sort it out from the In built mixer. I had to rasie the faders for the software returns 3/4.
You are a savior.
Regards
Head Phone Mix DonaldM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-08-2010 11:01 AM
Control 24 and head phone amp bellpro ICON & C|24 3 07-01-2007 06:56 PM
Using a head phone amp with control 24 bellpro ICON & C|24 7 03-01-2007 01:51 PM
Head phone amp... ghost22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-15-2006 07:47 PM
Head phone mix? sheeptuf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-27-2004 07:01 PM
