Avid Artist Mix for Logic Pro?
Does Avid Artist Mix work well enough for Logic Pro X?
I am comparing it with the Mackie MCU Pro. I had a great experience with Pro Tools vanilla and a 003 console, but for the time being I am intending to focus on Logic as my primary DAW. Thank you. Last edited by dsetto; 03-29-2017 at 09:58 PM. |
Re: Avid Artist Mix for Logic Pro?
i Use 2x artist mix with a 2008 Mac pro....and logic X... Its fantastic when it works!!!!....which is most of the time... though it does struggle with LARGEr projects.... Also it doesn't like FOLDERS...when the project is large...I do prog rock and have large track counts 120+ with 20 for drums..when switching into and out of the drum folder...you can loose contact with the controllers, and they go dead........ I'm not sure why....I have 20 gig of ram...so not sure what is causing it.....BUT !!!! I love them when they work..which is 100% with smaller projects.....It transforms the way you mix...thought the PAN knobs are CHEAP>!!!
Avid Artist Control + Logic problems. | matthihat | Artist Series | 4 | 02-03-2019 12:37 AM |
Artist Chat window in Avid Artist Community | taylor4814 | Pro Tools 2018 | 0 | 01-25-2017 06:30 AM |
Help Avid Artist Control losing connection with logic X using usb to ethernet adapter | smartinez5878 | Artist Series | 4 | 06-23-2014 11:10 PM |
Avid Artist Transport not working with Logic Pro X | heyrich | Artist Series | 1 | 03-21-2014 01:27 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
