Shortcut for "view channel strip" command?
I read PT shortcuts manual, and I can't find shortcut for this:
how to bring up channel strip of specific track in edit window. In other words - "view channel strip" command. It seems the only way to do that is with the mouse. And the button is very small... I am using PT 10.3.6 Does anyone know?
System Details: Host: iMac 27" QuadCore i7, 3.4GHz/32GB RAM/768 GB size internal SSD HD. OS X 10.8.3. Interface: Avid Mbox 3 Pro. Monitoring: Yamaha HS80M + Avantone MixCubes. Two external HD (7200 rpm, 64 cache): Buffalo DriveStation (for audio projects) + OWC Pro (for instruments' libraries). Instruments and plugins: NI Komplete 9 and East West Complete Composer's Collection 2 and other. Moved from Cubase 3 to PT10+MboxPro. Very happy with PT10! |
Re: Shortcut for "view channel strip" command?
I do not know of any shortcut to bring the "channel strip" into view, but :
you can bring all desired channel strips into view by shift-clicking the little symbol in the mix window and move/arrange them in the edit window and save this as a window configuration. And any other desired item : insert, send, ... . Before that, I usually make a blank/nothing/clear window configuration. Changing the window configuration is still with the mouse, but usefull. Window configs can be saved in conjunction with memory locations (those are shortcutable).
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thanks, joachim!
Like this:
ctrl+=
(brings up the whole mix window)
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
I don't think he's talking about the mix window from the picture he posted but the track output level control. And near as I know there's no keyboard shortcut for that.
In this case in mouse I trust
Thanks everyone!
Good, but what exactly were you referring to as channel strip - the output volume panel?
I believe : the "Output Window button" (p.959 , PT Ref Guide V.10.3)
Okay, but that's not what I or anyone else would call a channel strip. Channel strip is usually considered to be a plugin consisting of a preamp, eq and possibly dynamics.
Midi Clips View Problem, option + "-" keyboard shortcut broken | kingtinker | Pro Tools 10 | 5 | 09-25-2016 01:47 PM |
"Channel strip presets / storage" in PT11 | yeloop | Pro Tools 11 | 2 | 07-25-2013 06:35 PM |
Track/"Channel Strip" Presets DO exist in Pro Tools, apparently... | PTPhillip | Pro Tools 10 | 97 | 10-20-2012 01:03 AM |
shortcut for "view all tracks and regions"? | chagos | macOS | 5 | 03-10-2012 10:05 AM |
Probable bug in "notes" view on midi channel with smart tool | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-30-2009 11:07 AM |
