Old 07-27-2011, 01:30 AM
HansH HansH is offline
Default Colours on soft keys
Hi
I am having difficulties with getting the same strong colours on the softkeys I make, compared to the ones made by euphonix. Even if I copy the colour completely it looks different. And there is a dark blue background colour, can I get rid of that ?
Can someone help ?
Hans Henrik
Euphonix MC Control
Old 07-30-2011, 02:04 AM
Default Re: Colours on soft keys
Okay I found out that if I change a command on a softkey the colour become clear and strong until I choose the command in the last row in the Soft Key Command Editor. After chosen the command in the last row the colour becomes dull again.
Can anyone confirm if this is a bug only for Cubase only or it is EuControl bug ?
Hans Henrik
Old 04-17-2013, 11:08 AM
Voyageur Voyageur is offline
Hello,
I'm in the same situation : as soon as I choose a Eucon function, the color of the softkey is "dimed".
I'm affraid it's a Steinberg Eucon Adapter bug as the colors are OK with other functions or apps.
See this thread :
http://www.steinberg.net/forum/viewt...?f=184&t=35627
Old 04-25-2013, 03:53 AM
black_coffee black_coffee is offline
Hi guys,
EUCON commands can either be "On", "Off" or "One Shot". Depending on the command you are using, the colours brightness can be different.
For example, with Transport EUCON commands, the Play button will be dim until the DAW is in Play. At that point your Play command will be bright as that function is now On. When you Stop, Play is no longer active and will be Off and the button will dim. This brightness allows you to get feedback from the surface without looking at the screen because you will see what is on or off depending on the colour of the button.
Key Command buttons will always be bright because it doesn't know if the command sent is for On or Off.
Hope that helps.
Old 04-25-2013, 11:21 AM
Thank you for the answer, but actually, the sofkeys, except a few ones, are always "dark" (off)...
It's OK for the transport commands, but all other commands leads to a "oof" state color.
If I choose the same command via a keyboard shortcut, the color is bright again.
Is there a way to edit the state of the command (on, off, one shot) in the XML file ?
Old 04-25-2013, 02:00 PM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
The ON/OFF state is set by the EUCON command and is generated by the DAW adapter.
Key commands always default to bright (ON) state.
There is no way to edit this in the XML files. Sorry.
Old 09-26-2013, 06:04 AM
At mine machine all Key commands by default dark.
The only softkeys that is bright, is the type "Page : jump to page" to navigate on the touchscreen all other are dark.
I use Cubase 7 and the newest Eucon Control.
Export Soft Keys Tower Studio Artist Series 4 02-19-2014 06:03 AM
C24 soft keys PT HD problems Jipi-sensei ICON & C|24 0 12-03-2013 05:09 AM
soft keys for all pull ups in PT 10? Franklyn Artist Series 1 01-03-2012 01:22 PM
Soft Keys marrap Artist Series 4 11-28-2011 08:17 AM
adding Soft Keys? stainless Artist Series 5 06-23-2010 09:49 AM
