transport window disappeared
hi
not sure what happened... must have hit a key, mouse clicked something, i don't know but all of a sudden my transport window disappeared. tried minimizing windows... thinking it might hiding at the bottom somewhere - nothing! i checked and all the display settings look to be normal - it's just gone! could i have somehow sent it behind a track or somewhere? help please! 002r/inspiron 9200/gig of ram/etc... thanks t |
Re: transport window disappeared
go to windows then select transport
www.klarityrecordingstudios.com |
Display > Edit Window Shows > Transport View
At least thats how it toggles in 6.4. |
i believe your way puts the transport at the top of the edit window
while my way give's you the floating transport, but i am not 100% sure because i do not have PT open right now
that's the 1st thing i did - it's set to display and within the transport itself it's set to view everything midi, etc..
the transport at the top of the window is still there but not the floater t |
Have you changed your screen resolution recently or opened a session from someone else running at a larger screen resolution? Change your resolution to a high setting, restart Pro Tools and move the Transport Window to an area closer to the top left of the screen - quit Pro Tools and reset your resolution back.
Rail
hi rail i haven't changed any settings and i have closed down and restarted pt and my machine a few times still nothing... i open up pt and there is no floating transport window even though it set to display/view. t |
actually i had this problem once,
open an older session that you know the transport was there and if it you see it drag it to the center of the screen close the session then open up the other session where you could not find it before
terryd ,
Tried pressing >cntrl+1< ?
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
hi fellas
i don't have an older session this is my 1st / one and only i tried the ctrl+1 thing but it moves me thru the tools then i tried all the other shortcuts... ctrl+2, 3, 4, etc. i believe that this command only works on a numeric keypad like one you'd get with a desktop - i'm working on a laptop (dell inspiron 9200) i've had the machine for a couple months and after some initial tweaks has been great. this is the most bizarro thing i've ever seen - i can "show" everything and even though it says it's showing the transport - it's nowhere to be found. t |
Mix window disappeared | kg0ye | Tips & Tricks | 3 | 01-10-2011 11:44 AM |
Mix Window Disappeared | whiteboy_slim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-07-2009 03:53 PM |
Transport Window and Color Selection window lost | cd_audio_mix | Pro Tools TDM Systems (Mac) | 6 | 11-26-2006 10:58 PM |
Transport window disappeared!!!!! | tolovpeace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-08-2004 03:06 AM |
Transport Window Disappeared | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-02-2004 06:54 AM |
