Mbox 3 pro on Windows 10
My mbox 3 pro has had major problems since upgrading to windows 10, the audio will cut out for a period of a time and randomly come back on, over and over again.
Re: Fast Track Ultra and Windows 10
Can you post your full system specs? Are you using the latest driver? Try going through the Windows 8 Optimization Guide and see if that helps. But at the end of the day, as I mentioned above, Windows 10 is not qualified with Avid hardware or software yet.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Re: Mbox 3 pro on Windows 10
I'm using windows 10 64 bit. I switched back to the avid driver 1.0.19 and audio doesn't cut anymore. I haven't tried pro tools or cubase yet but it's stable browsing videos
Intel i5-2400 @ 3.10GHz
8 gb ram windows 10 home 64 bit Protools 8.0.5 LE |
LE8 won't run on Windows 10 which is very important. You need to update to PT12 or downgrade to Win 7 or something. If you try and install PT8 LE on a Win10 computer you will have major issues and use a lot of your time deleting old LE files as the system may not uninstall all the files.
Do you think LE8 will eventually run on windows 10 properly?
Also i'm in the process of installing windows 8 now. Will that work? |
LE8 will never run on Win10 or Win 8 so best scrap that old software and update to PT12 for $199 while you can. After 31st it will probably be double or not supported upgrade at all. LE8 is end of life and there is absolutely no way you can use it with newer Win Systems, sorry to report this.
Where can i upgrade for 199?
Also my problem isn't so much within protools than it is with windows itself. The mbox just seems to crap out all the time in windows 10. Do i need to get rid of my mbox 3 pro too?
The Mbox3 is not the issue, it is Win10 which isn't supported yet, not PT12 nor the Mbox3 drivers so if i were you i would downgrade to Win8 and use the Mbox3 with Pro Tools 12 until Win10 is supported and working.
Here is a link for upgrade to PT12 if you have the qualifying products http://www.sweetwater.com/store/detail/PT11LEup-e
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Original MBox with Windows Vista or Windows 7 | JoshuaD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-16-2009 06:57 AM |
Original MBox on Windows Vista or Windows 7 | JoshuaD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2009 06:50 AM |
Mbox on windows XP | soebx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-27-2003 08:50 AM |
Mbox and Windows ? | Eliza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-15-2002 06:53 AM |
