Old 02-19-2021, 05:12 PM
djangolives djangolives is offline
Default Win10 TP12 ,2020.12 & TP First Install but CRASH
Intalled PT12 started to crash. Error report as per pic "Driver IRQL Not Less or Equal" and "What failed AvidMBoxMini.sys. Performed all recommended Avid Windows Optimizations steps OK. Same hardware as when TP12 working. Obtained replacement iLok devise and purchased License Extension. All seems working OK.
Could not intall PT12 from my original saved .zip. Could not install PT2020.12 nor ProTools First without having system without same error crash as per pic. The SiSorftware report below follows. I can provide Error Log report if needed. Please advise how to install and use again.
Thanks
Edward/DjangoLives
SiSoftware Sandra Report
Host Name : DESKTOP-TQAG485
Workgroup : WORKGROUP
Computer
Model : Dell OptiPlex 9010
Serial Number : 67X****
Chassis : Dell Space-saving
Mainboard : Dell 0F3KHR
Serial Number : /67X3BZ1/CN7************
BIOS : Dell A15 08/12/2013
Intel vPro : 8.1.40.1416
Total Memory : 16GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (4C 8T 3.69GHz/3.9GHz, 3.7GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : Dell Core3 (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT351U6CFR8C-PB 4GB DIMM DDR3 2Rx8 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Memory Module : Micron 8JTF51264AZ-1G6E1 4GB DIMM DDR3 1Rx8 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Dell Computer DELL E1912H
(1366x768, 18.5")
Video Adapter : Intel(R) HD Graphics 4000 (128S 16C SM5.0 350MHz/1.15GHz, 320kB L2, 32MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL : Intel(R) HD Graphics 4000 (128S 16C SM1.2 350MHz/1.15GHz, 2MB L2, 1.4GB DDR3 1.6GHz 128-bit, Integrated Graphics)
D3D 11 : Intel(R) HD Graphics 4000 (128S 16C SM11.0 350MHz/1.15GHz, 320kB L2, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Storage Devices
Disk : KINGSTON SUV400S37240G (240GB, SATA600, M.2SSD, M.2)
Optical : HL-DT-ST DVD+/-RW GTA0N (448.2MB, SATA150, DVD+-RW, CD-RW)
Logical Storage Devices
Windows (C:) : 222GB (NTFS, 4kB) @ KINGSTON SUV400S37240G (240GB, SATA600, M.2SSD, M.2)
Hard Disk : 515MB (NTFS, 4kB) @ KINGSTON SUV400S37240G (240GB, SATA600, M.2SSD, M.2)
Windows RE tools : 515MB (NTFS, 4kB) @ KINGSTON SUV400S37240G (240GB, SATA600, M.2SSD, M.2)
SYSTEM : 96MB (FAT32, 1kB) @ KINGSTON SUV400S37240G (240GB, SATA600, M.2SSD, M.2)
Apps (D:) : 4GB (UDF, 2kB) @ HL-DT-ST DVD+/-RW GTA0N (448.2MB, SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller #1 : Dell Panther Point LPC Controller
Audio Device : Dell Panther Point High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Codec : Intel 2806
Serial Port(s) : 2
Disk Controller : Dell Panther Point 6 port SATA AHCI Controller
USB Controller #1 : Dell Panther Point USB xHCI Host Controller
USB Controller #2 : Dell Panther Point USB Enhanced Host Controller #2
USB Controller #3 : Dell Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : HP OfficeJet Pro 9020 series PCL-3 (600x600, Colour)
Printer : HP Color LaserJet Pro M478f-9f PCL-6 (V4) (600x600, Colour, Duplex)
Scanners & Cameras
Scanner : Microsoft HPB820A2.hsd1.ca.comcast.net (HP OfficeJet Pro 9020 series) (Scanner, USB)
Scanner : Microsoft HPB3A8E9.hsd1.ca.comcast.net (HP Color LaserJet Pro M478f-9f) (Scanner, USB)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Intel(R) 82579LM Gigabit Network Connection (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19042
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 02-19-2021, 06:11 PM
Default Re: Win10 TP12 ,2020.12 & TP First Install but CRASH
It's a third generation Mbox Mini? I'll assume it is.
"Driver IRQL Not Less or Equal" and "What failed AvidMBoxMini.sys." are both telling you it's likely not a Pro Tools issue. This is the Mbox Mini device driver. Messing around with Pro Tools is likely a total waste of time.
Do you have the latest Mbox Mini driver installed?
Even if you do try uninstalling and reinstalling it from a fresh clean driver download.
Try a different USB port and USB cable.
Test with a different interface.
This interface is about 2 years beyond end of life, has not had a driver update since 2014. Now may be the time to purchase a new interface.
Old 02-23-2021, 04:37 PM
TOM@METRO's Avatar
Let us know how your doing. It may help others as well.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-28-2021, 07:51 PM
sw rec sw rec is offline
Mismatched ram is a show stopper. All your ram sticks need to be identical.
Old 02-28-2021, 11:33 PM
Thank you for replay. This entire hardware was working for a couple of years and but for Win 10 updates.
Old 02-28-2021, 11:42 PM
Thank you for your response. Am waiting for new Focusrite scarlett 2i2 3Gen hardware.
Old 03-12-2021, 03:16 PM
Problem solved with Focusrite Scarlett 2i2 3rd Gen converter. Installed 2i2 and installed TP First OK. When PT started there was a nice pop-out that said Scarlett was clock synched with motherboard (this was, as best I could ascertain from prior error codes what was crashing my system). I was able to reinstall TP12 and plug-ins. I have a problem with system which I will put in new post: When I collapse the ap into the tool bar, the ap does not come back. PT icon stays in menu bar and if I hover cursor over menu bar icon, the ap icon pops up and then the entire scree shows the last view of the pre-close ap, but the ap will not activate. Must Task Manager End Process and reboot PT.
Mbox 2 Mini 2 on Win10 in 2020 GraphicJon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-05-2021 06:15 AM
Pro Tools 2020.9 installer failing on Win10 1909 danik Windows 13 11-19-2020 12:00 PM
Bug Report 2020.9.1 Clip Effects Crash PTs MikeReganNoise Pro Tools 2020 2 10-17-2020 02:49 PM
2020.5: AVE crashes, follows by PT crash home_studio Pro Tools 2020 0 06-26-2020 03:16 PM
[solved] can't start up for first time post-install (Win10/pt12.7) huzzam Pro Tools 12 3 01-25-2019 03:24 AM
