Re: 2021.3 and Mojave
Digitest is the only way I know to check firmware versions.
Maybe a new download-install will trigger the firmware install if it did’t take before. Install-power shutdown-wait 10sec, startup.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
There are problems with this version. Audio import which was mentioned earlier as well as some automation editing bugs. Expect a new version with fixes very soon.
In other threads there also appears to be a problem with the 2021.3 HD Driver. Avid support suggested to roll back to 2020.12.
I am also on Mojave, and I got the same error message with the HD Native engine as you reported. The Dolby Atmos Audio engine and Dante audio engines still worked. It seems that the 2021.3 driver breaks clock transmission from the interface back to PT.
I opened a case with AVID, and their suggestion of rolling back the HD Native driver fixed the issue here. Here's the link to the 2020.12 driver: https://cdn.avid.com/ProTools/2020.1...0.12.0_Mac.dmg After rolling back the driver my system is once again operational. Last edited by oldskool; 04-09-2021 at 02:32 PM. |
so 2020.12 is the best version? I`m asking because I`m still having problems with 2020.9.1 sometimes and I`m looking for a better version
Did you stay at PT 2021.3 and just roll back the driver, or are you back on 2020.X?
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
I'm on PT 2021.3 Ultimate. Only the HD Driver was rolled back to 2020.12.
I’m on Mojave with HDX with the 2013 Trash Can and I’m not getting any errors so far running PT 2021.3. I was prompted to update the HDX card firmware which I did successfully. Maybe it’s just a matter of time, or maybe my stereo music projects are not too complex/large.
PT 2024.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Studio M2 Max on Sonoma, 64GB RAM, 4 TB & 8 TB external SSD NVMe drives, Neve 1073OPX(2), Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VI’s and plug ins to mention. |
Yes, I was able to roll back to 2020.12 and all is working normally.
For kicks, I re-installed the 2021 HD driver. So 2021.3 now sort of works.. but it runs super wonky-- and loading a session is super slow. |
Same, except HD Native. Everything working great. Maybe Xeon processors make the difference.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
2021 & iZotope | Jazzbass56 | Pro Tools | 8 | 03-27-2021 07:03 AM |
aside from 2021 upgrade, anything else? | paul_g | Pro Tools | 3 | 03-26-2021 08:25 PM |
Anyone having issues with Security Update 2021-002 (Mojave) and PT 2020.12? | Cacov | Pro Tools 2020 | 3 | 02-28-2021 04:22 AM |
What is in store for PT in 2021? | Dave S. | General Discussion | 7 | 01-26-2021 01:10 PM |
