Old 07-04-2023, 08:59 AM
Siegfried Meier Siegfried Meier is offline
Default Transpose All Notes To...Broken!
This isn't working in the newest release...anyone else notice this?
File Type: png Screenshot 2023-07-04 at 11.58.02 AM.png (46.7 KB, 0 views)
Old 07-04-2023, 11:53 AM
Tweakhead Tweakhead is offline
Default Re: Transpose All Notes To...Broken!
Hey Siegfried, I just tested it, and it's working fine here.
Are you sure you've got the MIDI notes or region selected, and that you're hitting the correct "Apply" button (Transpose) ?
It's the one above the parameters you've chosen for correction, not the "Apply" button below. (Select/Split Notes)
It doesn't even look like your Transpose/Apply button is available for clicking. Try another setting in the box, eg D#3 and whether it becomes available then.
I'm not sure why only your Split button is available. That would seem to suggest that you have nothing selected, and have only an insertion point.
As soon as you have a MIDI region selected, all the Apply buttons should be available.
Old 07-05-2023, 08:47 AM
Ya, as before, I have my MIDI notes selected...but the issue is when I type in the note I want them all to be, it always reverts back to C#3 when I hit enter...
Are you not supposed to be able to type in what note you want all the notes to move to? That's how it used to work...I don't see why they'd change that?
File Type: jpg Screenshot 2023-07-05 at 11.45.39 AM.jpg (63.8 KB, 0 views)
Old 07-05-2023, 11:35 AM
Yes, you're right. It's definitely busted. That's not how it used to be.
The other transpose features work but not that one.
An important tool for drum replacement especially.
How on earth that one feature got broken boggles my mind.
Yet another fail for 2023.6
The only workaround is a 2-step process for now.
1. Set them all to C#3
2. "Transpose By" up or down by the desired number of semitones.
Old 07-14-2023, 01:51 PM
mrguitarguy mrguitarguy is offline
You can click the box and drag it up or down to other notes. This bug is extremely annoying and I hope it's fixed soon!
Big Sur 11.7.4, Pro Tools Ultimate 2023.6, HD Native, 2010 Mac Pro 5,1 3.46ghz 12 core, 128GB RAM, Radeon RX 580, 970 Evo M.2, 860 Evo, and Angelbird SSD drives. All PT optimizations followed to the letter.
Ventura 13.2.1, Pro Tools Ultimate 2023.9, M2 Pro Mac mini, 32GB RAM, 1TB SSD.
Old 07-25-2023, 11:04 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Absolutely broken, but...if you reverse the note direction, you get what you want. Think "opposite day."
If you want A2 to B2, it'll go down to G2, 'cause it's broken. But if you put in B2 to A2, it'll go to B2.
Avid, come on!!! How can you break **** like this?
Old 07-26-2023, 06:49 AM
MDGenerato's Avatar
MDGenerato MDGenerato is offline
Hi Siegfried! David here from the Community team. I've already gone ahead and created a case for the issue. The case number is 04658500. They will be contacting you soon to ask for more information. Thanks!
Old 07-27-2023, 01:11 PM
marianna's Avatar
marianna marianna is offline
Hi There... David has in fact created a case for you and Camille has responded asking a bunch of questions.
It would be great it you could add your specifications to your profile so we have that information immediately and can start working on it instead of asking you what you are on.... Just a request.
marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Transpose Shortcut Broken in 2018.7 NateAlexander Pro Tools 2018 16 09-24-2018 11:04 AM
Broken light XLR connector and broken is iLok USB port victorbraga98 VENUE Live Sound Systems 2 09-28-2015 10:48 PM
[PT11.3.1] TAB/alt+TAB MIDI Notes selection broken ? demodigi Pro Tools 11 2 04-02-2015 10:35 AM
Will Pro Tools Express Transpose notes like the regular Pro Tools? bbbbbbb40 Pro Tools Express on Windows 0 12-16-2014 05:25 PM
transpose Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-19-2009 08:44 PM
