Old 06-03-2022, 04:05 PM
DJ Hellfire DJ Hellfire is offline
Default Plugin keeps closing
How do you keep an open plugin window from closing when touching a pan knob on the S1 or when clicking a fader in Pro Tools?
The only way I found to get around this is by shift clicking a plugin window every time I open one or by closing the EuControl software, which obviously makes the S1 not work.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 06-09-2022, 12:17 PM
EddieJones's Avatar
Default Re: Plugin keeps closing
Look at the pref on the general tab in EuControl that control this. The user guide will help too.
Old 06-10-2022, 03:44 PM
Thanks. I actually found it. It is the "Close windows on workstation when exiting" setting. I didn't try this one before because I thought it was specific only to closing the plugin window when closing the plugin from the S1. But apparently it also affects using plugins in the workstation as well.
Pro Tools 2021.12
Old 06-05-2023, 12:10 PM
zakco zakco is offline
I've unchecked the "Close windows on workstation when exiting" in Eucon prefs. I've noticed that touching any encoder on the S1 with close whatever plugin GUI is open at that time. I understand this behaviour would be desirable when selecting a new attention channel but why does it need to close unrelated plugin windows when a new channel is not "attentioned"?
Workflow example: I have a reverb plugin gui (inserted on aux) open and I'm adjusting parameters. To check my adjustments, I'm sending it varying amounts from different audio track sends. Every time I touch a rotary encoder on the S1, it closes the plugin GUI. If I remember correctly, this didn't happen on my D-Command.
I realize I can uncheck the litte red swich on the top right of the plugin gui to stop this from happening but that means I will need to use the mouse to close that GUI eventually, instead of it going away when I finally attention a different channel.
Is there a preference somewhere that changes this behaviour?
Old 06-07-2023, 11:13 AM
EddieJones's Avatar
What knob are you pressing, Pan? What do you have this set to? Open windows on Workstation when Editing. Try selecting just Plugins.
Old 06-14-2023, 02:31 PM
Yes, this is exactly what I was looking for...thanks Eddie!
Edit: In that case, I was touching (not pressing) the S1 rotary encoder.
Top|Back not closing plugin like Eucon 3.6 ripekeai Avid S1, S3, Dock and Control App 5 11-03-2017 05:43 AM
Pro Tools hangs when closing plugin window George2000 Windows 6 09-12-2017 03:26 PM
Plugin written automation is gone after closing protools sabinacovarrubias Pro Tools 12 1 06-29-2017 12:42 PM
Top/Back button not closing plugin? Tim R. Avid S1, S3, Dock and Control App 5 02-12-2016 08:26 PM
Key command for closing plugin windows? IO Composer Pro Tools TDM Systems (Mac) 9 08-10-2009 04:38 AM
