Old 12-16-2018, 07:06 AM
Becharax's Avatar
Becharax Becharax is offline
Default Pro Tools 2018.12 Error !
Hello Guys,
Using .12 and I don't know why for some tracks sometimes I get the following error : Assertion in "/Volumes/Development/223020/ProTools/NewFileLibs/Sys/MacOS/Sys_FileLocMacOS.cpp", line 230.
(Use the Copy button to copy this message to the clipboard.)
Can you please explain what's that ??!
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 12-16-2018, 07:20 AM
Becharax's Avatar
Default Re: Pro Tools 2018.12 Error !
I read it has to do with the playback engine but I didn't change anything related to that .. and by the way ... I cannot replicate the error again ... it disappeared all by itself without me doing anything ... I don't know if it might pop up again sometime randomly within a session .. is there anything i should do ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 12-17-2018, 11:20 PM
Becharax's Avatar
BUMP ! Moderator ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 12-18-2018, 01:58 AM
danyg danyg is offline
I had it too on a session without knowing why and it came back but I found a workaround.
Go to the playback engine and change it to "... whatever" and change it back to your standard audio interface and press save. Now the session plays coreectly.
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 12-18-2018, 01:59 AM
Becharax's Avatar
I didn't even change anything man ... and the session got back to playing correctly ... but can someone from the mods elaborate or is it a bug ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 01-05-2019, 03:01 PM
feliponk's Avatar
feliponk feliponk is offline
It just happened to me, and as danyg mentioned, changing the playback engine to another and then returning to my default one solved the problem.
Can anybody else confirm this, please?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 10-30-2019, 01:35 PM
paulcheeba paulcheeba is offline
I just got this: Assertion in "/Volumes/Development/238950/ProTools/NewFileLibs/Sys/MacOS/Sys_FileLocMacOS.cpp", line 230.
After upgrading from 2018.12 to 2019.5 on High Sierra. It's happening every time I try to add a plug in. Changing playback engine doesn't help.
Anyone got the solution yet?
Thanks
Paul
Old 11-22-2019, 11:00 AM
pmcaster pmcaster is offline
Hello, I have the same error, it's impossible to insert any plugin, I'm desperate and I need to open a session urgently, any advice to fix this issue?I'm using Protools 2019.10 with Mojave
Old 11-22-2019, 11:49 AM
Southsidemusic's Avatar
Try starting PT with the N key held down and when popup windows comes up choose your inteface and see if that helps.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-22-2019, 12:36 PM
No, unfortunately it doesn't work, I'm really desperate with this issue, should I contact directly Avid?
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
AAF import error in 2018.3 rhumphries Post - Surround - Video 1 05-29-2018 03:48 PM
iLok Error with PT 2018 midi sordino Pro Tools 2018 2 04-20-2018 04:24 PM
Pro Tools Ultimate 2018.4 GUI offset by tabs error Mike Ritchie Pro Tools 2018 2 04-10-2018 03:49 PM
Pro Tools 2018.1: Error in Controller-Personality "EUCON" ... johab Pro Tools 2018 0 03-02-2018 01:40 PM
