Old 07-08-2018, 06:26 PM
MSCHAAF MSCHAAF is offline
Default Debilitating Stutter Freeze
I have a iMac OS 10.9.5 and pro tools 11.3.1 and a focusrite clarett8 pre. From what I remember this problem began to manifest as I upgraded PT throughout the years so I'm reluctant to think that PT 12 will be any different. I used to go 8+ hour sessions at a time and no crashes with my mbox2 pro and PT 7. I've done pretty much everything I've read on here and directly from AVID, all the recommended optimizations, checked compatibilities, etc.
I get this frozen stutter, and I know this is a specific glitch, so I'm wondering if anyone else has experienced this before and knows why it might be happening. I cannot force quit PT once this happens, it really seems entirely random, and I have to hold the power button on my mac to shut down and restart. That's the only way out...
I cannot go 15 minutes of editing without this stuttering crash, and it makes me hate working on music as I can no longer dive in deep with 8+ hour sessions like I used to.
Here's a quick video of what the freeze stutter looks like.
https://youtu.be/6GqyWzCig1A
If you've personally experienced this too, I'd owe you my life for a stable fix.
Thank you.
Old 07-08-2018, 06:50 PM
BScout BScout is offline
Default Re: Debilitating Stutter Freeze
Try your in-built audio.
Pretty sure your audio issue is due to the focusrite drivers.
Also, if you are sticking with 11, you should really upgrade your macOS to Yosemite (10.10.5) and the last 11 (11.3.2). They were very stable together. Much better than Mavericks.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 07-08-2018, 07:22 PM
Thanks for the ideas, I'll try 10.10.5 w/ 10.3.2 but and working with built-in audio.. would I just us an aggregate audio device w/ the focusrite interface?
Old 07-08-2018, 08:02 PM
11.3.2 (first off) for Pro Tools if you are on 11 (I'm assuming that was a typo)
No. No focusrite at all. No aggregate audio at all. You can assign Pro Tools to use the audio output of the iMac (you have digital and analogue options for audio out.) Set it to the analogue and sound will come out the built in speakers (or headphones if you plug them in.) Try it and see if you have issues.
Old 07-09-2018, 02:10 AM
Southsidemusic's Avatar
Good advice.
Start PT with the N key held down until you get a popup window where you choose internal soundcard or built in audio whatever it is called and let PT load up.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-09-2018, 12:02 PM
crossing my fingers but switching to built in audio seems to have done the trick... thank you so so much for that suggestion
now i need a new interface, what would be the most stable for mac os apart from HD gear... RME?
Old 07-09-2018, 01:34 PM
Depends on how much I/O you need and how much money. And also what you have in the way of ports on your computer. Generally RME is considered excellent with stable drivers but not cheap. Somewhat cheaper are variuous MOTU interfaces. If you have FW800 and want some dsp help there's the UAD Apollo silverface unit.
Jack
QAPLA!
Old 07-09-2018, 02:09 PM
Right, I feel ya. I am only concerned with stability at this point. I'd much rather have to find a creative work around to less IO than deal with tech malfunctions.
Old 07-09-2018, 02:10 PM
RME easily (though they've reported -- and other manufacturers -- that Apple made changes to CoreAudio in High Sierra that is creating some problems; so stay off of High Sierra).
But I'd check that you have all your firmware/drivers up-to-date on the Focusrite. They've had a lot of issues with their USB audio interfaces but reports are they are now fixed. Just make sure you first wipe out anything to do with the Focusrite drivers from your system, reboot, and then pull the latest drivers/firmware from Focusrite's website and see if it fixes it.
Old 07-10-2018, 01:49 PM
Arrow Re: Debilitating Stutter Freeze
This sounds similar to an issue a friend of mine had with a Grace interface, which is to say that you may want to avoid their interfaces in this particular configuration.
Pro Tools 10 HD (Cursor Freeze/Playback Freeze) vinlance Pro Tools 10 1 07-13-2013 11:40 AM
Debilitating new error message Stuart P. Pro Tools TDM Systems (Mac) 17 03-21-2010 10:19 AM
QT Stutter jjsoundoc Post - Surround - Video 1 10-31-2009 09:28 PM
Stutter When Using USB HUB edfermi MIDI 0 08-28-2009 09:28 AM
Stutter effect t0rn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-09-2009 08:36 PM
