Old 01-26-2018, 08:12 PM
BScout BScout is offline
Default Re: Lost HEAT in 2018 Install
I see you are running El Cap. I know it is approved but I don't know anyone running it for Pro Tools (everyone I know went from Yosemite to Sierra or High Sierra.)
You said you wiped everything. Did you do/use this to make sure everything is gone?:
http://petegates.com/pg-pt-prefs.html
Have you rebooted?
What does the Application Manager say? Does it recognize you running/installed Pro Tools HD 2018.01?
No problems with Heat on Sierra for me.
Also have you double checked the Heat license is showing on your iLok and have you done an ilok key synchronize? (sign in, click on ilok key, right click, select synchronize)
Old 01-26-2018, 08:22 PM
zeeman zeeman is online now
Hey,
My Machine won't go to Sierra. El Cap is as far as i can go. And yes to everything else you stated. Using Pete's Pref App.
HEAT is showing on my ILOK. Did a sync,
App Manager shows PT2018.01 Shows everything else up to date.
This is def a weird one.
Prob going back to Pt12.8.1 where things have been running really smooth.
Bummed for sure.
Digging the new features.
thx for your help and info
z
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 01-26-2018, 08:42 PM
Got it.
Pulled out my ILOK( which i did do once already)and reinserted but this time did a sync right after and sure enough HEAT came back.
BScout thx for your help. "And if so, go to your iLok key, right click on it while logged in, and choose "synchronize"
I think that's what did it.
Much appreciated.
z
MAC OS 13.6.1
PT 2023.12
Old 11-23-2019, 12:31 PM
tmuzik tmuzik is offline
Same thing happened here with PT 2019.6.
loaded sessions and dialog box would popup reading:
"HEAT Is Not Active
This session was last saved with the HEAT option active and thus may sound different on the current system. HEAT settings will not be lost when this session is next opened on a Pro Tools system which has HEAT available, but will be inactive."
Opened my iLOK License Manager and saw HEAT was a light grey color.
I right clicked and selected "refresh"
Closed and reopened PT.
All is good now.
Who is John Galt?
Old 11-23-2019, 12:35 PM
JFreak's Avatar
JFreak JFreak is online now
HEAT is always installed. Whether you can use it or not depends if you have the license. If you have the license and it still does not work, contact Avid Support to check what is wrong with the license.
Janne
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 07:43 AM
Possible prefs question relating to Heat install bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 02:50 PM
Lost install cd for LE 7.3 b_rod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-06-2008 12:49 AM
Lost 7.3 - How to re-install? voxblue Pro Tools M-Powered (Mac) 3 06-03-2007 11:50 AM
Lost install? PT5 roderickelms Pro Tools TDM Systems (Mac) 14 04-19-2000 03:37 PM
