  #331
Old 12-19-2016, 04:21 AM
rubenmarcano rubenmarcano is offline
Default Re: Avid Core Audio with HDX/HD Native on Yosemite/later Mac OS
Thank you so much I noticed what yuh mean and yes the avid buffer was at 256 while the DAW was at 32.
Thank you so much
Ruben
Originally Posted by Marco Bernardo View Post
Check the image
The buffer size inside Cubase is not linked to the avid core audio option panel.
Who's fault?! who cares (at least for me that I'm learning how to code and I understand some things can't be made period, I'm not saying that this can't be fixed ok but it must be a effort for both manufactures)
Yes I have Logic too, but not used in a long time. Not even customers ...
Hope it helps.
ps: don't forget that those kind of latency setups eat up CPU like biatc**"#$
  #332
Old 12-21-2016, 03:24 AM
youngas75 youngas75 is offline
Originally Posted by Blues Bird View Post
Is it possible now to adress outputs different then 1/2?
bump on this. Just installed but can only get out from 1+2 and my XMON needs 1+5.
  #333
Old 12-21-2016, 04:08 AM
Drew Mazurek's Avatar
1. There's an X-Mon mode check box in the setup window.
2. you can configure it to use any outputs you like in Audio/MIDI set up app by click configure device or configure speaker outputs.
I use an Apogee Symphony I/O which needs to be "3rd" inline so my main outputs are actually 33 and 37 (I think, can't remember right now)
www.drewmazurek.com
  #334
Old 12-21-2016, 06:53 AM
Ahhh yeah, I was looking for the little app that used to launch when the driver was running but I see they've embedded it. Cool, thanks for the pointer!
  #335
Old 12-21-2016, 11:31 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
As Drew Mazurek said now with pictures.
Open Audio midi setup (follow the red arrows)
1st Picture
2nd Picture
Cheers
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
  #336
Old 02-03-2017, 06:55 AM
pinosmuse pinosmuse is offline
A few weeks ago I installed Harrison Mixbus and protools 12.7 with the HD driver.
Everything working fine. I saw all my devices neatly in the audio/midi utility.
I didn't need anything but PT last weeks, but yesterday I wanted to check and the HDX output option was gone. Next to that my converters (lynx aurora with LT-HD) revert to 192KHz when shutting down protools...
Only thing I changed in my MacPro is a new videocard (gone up to a 5770 card)
Any ideas what can cause this?
HDX-1 MacPro5,1 Raven MTi2, PT12.7
  #337
Old 02-03-2017, 08:15 AM
It seems to be a combination with the aurora in my case.
When I log in to my computer it reverts to 192KHz and gives signs of stress (signal leds getting freaky). When switching it to 96KHz or below everything is fine.
I just ran digitest and it gave some failure messages. I'll contact Lynx for that.
After the test I restarted and switched the aurora's to 96KHz and started th audio midi utility and the Avid HDX shows itself again.
  #338
Old 02-06-2017, 01:29 PM
gdfclub gdfclub is offline
Avid Digidesign Pro Tools HD Core Audio Functionality with El Capitan Hd Driver 12 6 1
I hope this is the right thread where to post it
Hi everybody,
i've got a MacPro (early 2009) with digidesign 96 i/o and pro tools HD2 (one core card and one accel card PCIe).
Everything works fine on my first partition Snow Leopard (OS X 10.6.8) and here i use Logic Pro 9 and Pro Tools 8.0
Now, i made another partition El Capitan (OS X 10.11.6) and here is my problem.
With El Capitan I just wanna use core audio features with third parts daws (Logic Pro X).
As you can read within avid pages (
http://avid.force.com/pkb/articles/r...er-v12-3-Notes
) it would be sufficient installing 'hd driver 12.6.1' to achive this.
I finally could install this driver but nothing seems to work.
DigiTest don't even see pcie slots.
From the audio setting panel of macpro there are not input/output of the digidesign.
What am i doing wrong? Please help i have to work with logic x upon two projects
  #339
Old 03-16-2017, 04:42 PM
Hi everybody,
hummmm you're trying to use a HDX PCIe / HD Native PCIe/TB driver with your TDM system... hummm
The latest HD TDM driver is with PT HD10 and the latest supported macOS is Mountain Lion or Mavericks (I can't remember, please google it)
You can't even install HD 10 (officially in any other macOS after Mavericks).
short answer you can't, sorry.
Marco Bernardo
  #340
Old 03-21-2017, 12:27 PM
mu-tron-kid mu-tron-kid is offline
Location: Ithaca College School Of Music, Theatre, and Dance
HD Driver 12.7.1 finally fixes this issue!
http://avid.force.com/pkb/articles/f...e-Audio-on-Mac
I have run it successfully with PT 12.5.2 and 12.7.1
One interesting issue on HDX is that Safari>YouTube plays back out of Outputs 1-2 (as expected), but a website with an embedded Twitter Video played the audio out of Output 3 !
Not sure if this is some sort of Mac OS vs. AVID Mono routing or something, but there seems to be no way to adjust this...
****UPDATE: reseting the Mac OS AudioMIDI Setup app's "CONFIGURE SPEAKERS" section to Left:1 / Right:2 seems to have fixed this.
One MAJOR drag with AVID's solution is that it is "either / or" as to which software is accessing the HDX Cards: If you are running Izotope RX Spectral Repair as Audiosuite, RX cannot use the HDX Hardware to output the audio you are working on!
This is the same disastrous workflow issue that existed before.
Brian Dozoretz
ACSR
ACI Dolby Atmos
Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink,
Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4
VENUE SC48 3.2 with iPad Control
SSL Duality
SSL Duality via ipMIDI / ∂elta Automation Plug-In
Avid Core Audio HD Driver Breaks Maschine in Yosemite ronwasserman macOS 41 12-10-2015 04:05 PM
Native instruments Maschine not opening in Yosemite OS bc of Avid Core audio Driver? amos922 Pro Tools 12 4 06-18-2015 12:27 PM
Avid hd native core card used $1200 Killbert Buy & Sell 3 01-14-2014 06:16 PM
AVID HD NATIVE PCIe CORE CARD CHEAP!!! Killbert Buy & Sell 0 01-09-2014 06:44 AM
