Old 10-06-2013, 07:23 AM
Damosound Damosound is offline
Default Pro Tools 11.0.2 SOLO Mode keeps defaulting to Latch
My SOLO mode keeps defaulting back to Latch, even though I always set it to X-OR. I don't have problems shutting down or starting up. None of my other settings seem to change upon reboot.
Damosound
Pro Tools 11.0.2
OS 10.8.4
3.4 Ghz Intel Core i7
32 GB 1600 Mhz DDR3
HD OMNI Thunderbolt
Blackmagic Intensity Shuttle 9.7.9
Old 10-07-2013, 01:58 PM
Stig Eliassen's Avatar
Default Re: Pro Tools 11.0.2 SOLO Mode keeps defaulting to Latch
It works fine here. Have you tried to delete the Pro Tools Preferences (scroll to the middle of the page)?
Old 10-19-2013, 05:05 PM
Thanks Stig. Yes. Of course. It's more intermittent after I toasted the PRAM, dumped my preferences etc but the issue persists. I have also found issues with Maxim not retaining its settings properly, even when automating.
Damosound
Pro Tools 11.0.2
OS 10.8.4
32 GB 1600 Mhz DDR3
HD OMNI Thunderbolt
Old 10-24-2013, 09:21 PM
YKlein YKlein is offline
I'm also having trouble with the solo
Old 09-23-2014, 01:57 PM
kkabel kkabel is offline
I'm having this problem too. I read in another post that it might be connected to using the Artist Mix (which I do). I have had this problem since PT 10. I am now on 11.2.1 and OS 10.9.3 and the bug persists. Tried all sorts of pref. resets too and it didn't help. Did any of you find a solution?
Old 09-23-2014, 03:26 PM
Farhoof's Avatar
Farhoof Farhoof is offline
Is it fixed when you rename the Protools 11 application in your Applications folder from "Protools.app" to "Protools 11.app". You might have to rename PT 10 to "Protools 10.app"
Don't add the .app if you don't see it now (it's hidden), then just rename to "Protools 11".
Solo Latch Dialog in PT 7.3? MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-03-2007 08:11 PM
Latch solo in PT HD 7.3? bentsounds Pro Tools TDM Systems (Mac) 2 01-09-2007 06:29 PM
No Latch Solo Buttons option in 6.9 preferences. Eric Heil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-12-2005 09:10 AM
'Latch' Talkback Mode steve m soundworks ICON & C|24 2 03-28-2005 05:43 AM
Latch solo buttons Zownd Pro Tools TDM Systems (Mac) 0 04-27-2002 06:20 AM
