Old 11-08-2012, 06:16 AM
Rockman413 Rockman413 is offline
Default Can't import video when frame rate not the same as the current one
Can't import video when frame rate not the same as the current one, but actually I killed/deleted the whole thing related to the previous video.
So my first video track is 23.98 frame, then I delete it, also in the Tracks (left of PT), then I select to import another video track which is 24 frame, and I still get "Can't import the selected video file because it does not have the same frame rate as the current video in the session"
Old 11-08-2012, 06:30 AM
Question Re: Can't import video when frame rate not the same as the current one
Did you delete the original video you had imported from the clip list? If not, delete the original video you had imported from the clip list and then try to import this second video file.
Old 11-08-2012, 08:52 AM
plastikman plastikman is offline
Default Re: Can't import video when frame rate not the same as the current one
+1
For whatever reason, if the video still exists in the clip list (on right side), whether it's on the timeline or not, it will not import a new video at different frame rate.
Originally Posted by Dizzi45Z View Post
Pro Tools doesn't ever not cease to not amaze me.
cannot import second video file! different frame rate message. crizdee Pro Tools TDM Systems (Mac) 6 10-14-2008 09:10 AM
How do I import an omf with a frame rate of 59.94? AudioAlchemy.tv Post - Surround - Video 2 09-08-2007 03:55 PM
Same video frame rate still won't import - too often anyway Farmer Dave Pro Tools TDM Systems (Mac) 3 07-23-2007 07:22 PM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
7.2 BUG - Video import w/different frame-rate Charles Deenen Pro Tools TDM Systems (Mac) 4 08-08-2006 01:23 PM
