Help setting up an Oxygen49 controller
Hello all,
I recently picked up Pro Tools MP 9 and the M-Audio Mobile Pre interface. I have been using Cubase for a very long time now. So far everything is working great. I just have a couple things that are going to make me pull my hair out. I am currently using Reason 5 for my drum and synth / piano tracks. I have gotten to the point where I am running Reason in ReWire slave mode. My problem is this. I would like to be able record in real time in PT 9 using the audio from my devices in Reason. I have followed all of the instructions from the propellerhead site: http://www.propellerheads.se/substan...icle=protools2 to route the signal. However when I go Setup > MIDI > MIDI Studio Setup to set up my controller, the M-Audio brand does not show up in the provided list. How do I get Pro Tools MP 9 to recognize my M-Audio Oxygen49 USB controller? HELP! =) |
Re: Help setting up an Oxygen49 controller
I noticed you posted this a few days ago...If you've already figured out, then disregard.
SELF BUILT PC: WINDOWS 10 (64-BIT), INTEL I7-7700K CPU @ 4.20GHZ, 32 GB RAM INTERFACE: RME FIREFACE UFX+, ELEVEN RACK PRO TOOLS: PT2019.10 |
My AxiomPro 49 didn't show either, I found it funny that M-Audio isn't listed being that Avid & M-audio are so intertwined ....
I added it manually then made sure it's listed in "Pref>Midi/Sync tab>controlled surfaces;" chosing the ins/outs."
Healing the world through music................. Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64 PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete RME BabyFace|AxiomPro49|Akai LPD8 |
Check the drivers and reinstall them. Reinstall the latest drivers from the M-Audio website. Make sure you check things thoroughly in Input Devices. Check to see if other software recognizes the devices in question. Also check PERIPHERALS and make sure MTC is checked also to get things going for the Play/Start button!
Give Me Apps |
Help with setting up my MIDI controller! | elsterNJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-08-2010 12:36 AM |
Oxygen49 MIDI controller powers itself off!!! | [email protected] | MIDI | 1 | 02-10-2010 07:26 PM |
Setting up midi controller | Nashville Cat | Virtual Instruments | 1 | 08-27-2007 07:11 PM |
Help trying to control pro tools w/ oxygen49 midi controller | aidanm | Pro Tools M-Powered (Mac) | 1 | 07-02-2007 07:44 AM |
Setting up controller templates... | holdfast | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-14-2005 12:02 PM |
