Old 10-10-2010, 03:04 PM
Holyoli Holyoli is offline
Default Eleven rack and cubase : monitoring problem
The problem I have is basically the same as this one, here with logic :
http://duc.digidesign.com/showthread...put+monitoring
When I record a track in cubase and listen to it during recording, I hear the recorded track + the stand alone 11R in the phones. With the latency, it sounds like a bad doubler. With my other interface (e mu 1820 m) it's very simple to mute a track to avoid direct monitoring but here ...
I have looked and searched for hours, so am I missing something or is there an interface problem with non PT daw ?
Thanks.
Old 10-10-2010, 03:49 PM
Default Re: Eleven rack and cubase : monitoring problem
This is a quick one
I was probably missing that I lack sleep...
The solution was in the Windows control panel, sounds : select eleven rack everywhere, it works like a charm.
I go to bed now
Eleven Rack questions - monitoring & rig settings mrllnfn Eleven Rack 2 02-20-2013 09:25 PM
Eleven Rack monitoring? saheyl macOS 1 02-01-2013 10:53 PM
Eleven Rack & in-ear monitoring DonaldR Eleven Rack 1 03-10-2012 05:50 PM
Vocalrecording - Eleven Rack - Low Latency Monitoring? wiseman Eleven Rack 8 07-01-2011 06:52 AM
Problem with direct monitoring in Cubase justaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-28-2010 03:37 AM
