Old 09-08-2007, 01:54 PM
AudioAlchemy.tv AudioAlchemy.tv is offline
Default How do I import an omf with a frame rate of 59.94?
I'm working on a Hi-Def project coming from FCP with a 59.94, drop-frame time code. When I import this into Pro Tools 7.3.1 it offsets the 01:00:00:00 time code to 02:00:00:00 and recognizes the file as non-drop frame. There also seems to be a certain amount of drift over the duration of the project regardless of whether or not I change the time code to drop frame.
Any ideas? Solutions?
Thanks,
Dave Smith
AudioAlchemy.tv
Old 09-08-2007, 03:45 PM
EarHole EarHole is offline
Default Re: How do I import an omf with a frame rate of 59.94?
59.94 is a phantom rate. it doesn't really exist. I'm pretty sure it's just 29.97 (29.97 x2 = 59.94) NDF.
Old 09-08-2007, 03:55 PM
minister's Avatar
minister minister is offline
59l.94 is not a frame rate.
it is either 23.976 or 29.97 (D or ND)
are you translating an OMF?
are you opening (or double-clicking it)?
or are you importing tracks into an aleady existing (even new) session. if so, are you sure that your Session start time and the OMF are the same? and are you remapping the incoming tracks? if so, then that explains the discrepancy.
unless the editor set it up for 2 Hours. or this is Reel 02.
if you are having drift and it came from Final Cut, then have the eidtor check into whether or not he properly removed advanced pull down (not the audio pull down). editors new to HD make this mistake all the time.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
HTML code is On
Can't import video when frame rate not the same as the current one Rockman413 Pro Tools 10 2 11-08-2012 08:52 AM
cannot import second video file! different frame rate message. crizdee Pro Tools TDM Systems (Mac) 6 10-14-2008 09:10 AM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
Same video frame rate still won't import - too often anyway Farmer Dave Pro Tools TDM Systems (Mac) 3 07-23-2007 07:22 PM
7.2 BUG - Video import w/different frame-rate Charles Deenen Pro Tools TDM Systems (Mac) 4 08-08-2006 01:23 PM
