  #21
Old 07-20-2001, 09:05 AM
guitates guitates is offline
Default Re: Cd Burning speeds
The people Burning the Glass Master work for You, so the will "clock" the way you tell them 2...Eh?? Mastering Handbook says to tell them to burn at 1x... [img]images/icons/cool.gif[/img]
I Seek the Holy Light...
Isaiah 40:31
72 Strat with single 2-Blade pickup
PTLE 10.3 LE
2-SSL Alpha Channels - 1 SSL G-Compressor
Apogee Rosetta 200 - Z-Systems Opti-patch
Lexicon MPX-G2 Guitar Processor - .003r
Command 8 - Roland JV1000 + Triton Rack
FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom
2-52 jax MilSpeck Patch Bays
2-22" Apple Cinema Display's
Allen & Heath 16ch Mixr
**Currently = 11-1-12
2 CD's Released-1-2003-2-2012 Worship ROCK
  #22
Old 07-21-2001, 10:11 AM
Chromefree Chromefree is offline
Putting together PT Mix Plus studio and I want to buy a pro audio cd-r. Was about to get the yamaha cd-r 1000 when I learned it's discontinued. I'm now looking at Tascam CD-RW 2000 but it doesn't seem to be up to the Yam's class.
Anyone have experience with either of these two babies?
Also: Do I mix down to DAT or directly to CD?
Thanks all for your input!
__________________________________________
Pro Tools HD 2 TDM System, Digidesign 96i i/o interface, Magma Expansion Box with 1-HD Core card, 1-HD Accel card
Pro Tools 10.3.8.378
Mac Pro 2x2.4 GHz 6-Core Intel Xeon
32 GB ram, 250 GB Samsung 840 Pro SSD sytem drive
1TB WD Media drive
OS 10.8.5
  #23
Old 07-21-2001, 07:19 PM
Kurtstudio Kurtstudio is offline
always burn to CD. Dats correct errors and cd replacates your mix perfect. The burner to buy is the Masterlink 24 bit burner, I also have the Fostex CDr 300, it works great as a stand alone. The Masterlink 9600 CDr from Allisis has become a standard at Mastering labs for 24 bit mixs but the converters aren't great. I use my apogee as the converters. Good luck, Sony just came out with a cdr also. FYI all the cdr are made by the same company in Japan anyway, HHB has a great one also. [img]images/icons/tongue.gif[/img]
Later, Kurt
[email protected]
Intel duel Quad core
PT 8.0cs3
HD4
D Command / D control
  #24
Old 07-23-2001, 09:05 AM
Kurtstudio--So your saying that the standard is to burn at 24bit and leave the 16 bit conversion and the application of the dither to the Replicators??
I have read that the producer would want to control these things and Not leave it to the replicators?? [img]images/icons/confused.gif[/img]
Isaiah 40:31
PTLE 10.3 LE
  #25
Old 07-23-2001, 07:41 PM
Yes, I also suggest that you are there when the mastering is done. The all oarties are happy. The only minus is tha malstelink has low tollerence for Peak levels, a cd that plays fine on all players might distort or digi noise on the masterlink, the wprk around is to load the aong into the harddisk and it plays back fine. [img]images/icons/smile.gif[/img]
Later, Kurt
[email protected]
PT 8.0cs3
HD4
  #26
Old 09-20-2001, 02:25 AM
delphypop delphypop is offline
I've had someone tell me they could hear the difference between different media types. one being crisper that the other or warmer etc.
personally I don't see how it can be. it's one's and zeros. it's either a one or a zero and if it isn't it's an error.
If there's a high error rate then the error correction of cd player you're playing it back on kicks in and you get variations in sound.
I tend to dismiss people who say they can hear undefined quantities as "warmth", and "richness", fullness. I think a lot of it is imagined.
I had a guy who swore that his pressed cd sounded incredibly different to the CDR master I burnt for him. Not as rich warm and full etc. I couldn't hear any difference and I loaded it back into protools, flipped the phase on it and played it back against the original version and it cancelled out completely, silence, no sound, no difference between the duplicate file and my original.
  #27
Old 09-22-2001, 01:16 PM
OK--So how many BLER's are allowable on the Glass Master??
I Never heard of BLER free CD's--Have You??
What about this jitter thang?? huh??
So what about signal to noise ratio??
All CD's the same?? Can't hear the difference?? How long you been doin this??
Isaiah 40:31
PTLE 10.3 LE
  #28
Old 09-23-2001, 02:40 PM
how does sinal to noise ratio come into it with a direct digital transfer of information?
Isn't Signal to noise ratio to do with the analogue demain where you have machine noise to combat.
Yes bler and jitter are important factors.
I took the lid off my yamaha and pointed a big fan at it and it resulted in the best burns I've ever had.
yes some cds have more errors than others but I heard this in audible clicks, not change in tone.
Burning a cd is not the same process as dubbing a tape. There are a whole different bunch of factors to consider that produce different side effects, I don't think changing tone is one of them. If there is what you percieve as a change in tone it is perhaps actually something else, a mushing of the sound from error correction perhaps? (hey isn't that warmth)
And I've been doing "it" for many years and I've learnt to not waste good mixing time on hypotheticals. I want to see the test sheets and have good explaination. The mind can play tricks on you. i've seen that more than anything else in this business. Ever had the "more foldback, yes that's fine be for you've touched anything" scenario?
The local hi fi store told me some people were saying optical cables had different sounds. Well if they do then I'd like to know why. it's a one or a zero and it goes through the light pipe/ spidif to the amp. if it doesn't come out the same one or zero when it hits the amp then it's an error. That's all that's happening there. There is no other electronic processing going on, just transfer of data.
the main thing I'm concerned with in burning CDs is Clicks from errors. some media are terrible at this and others not. all work better with good cooling which I think sharpens the burn.
Thats all I know
  #29
Old 09-23-2001, 05:58 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is online now
Only the data is digital. Everything than handles it is analog.
Potentially all digital code can be decoded perfectly. In practice a lot of gear leaves a bit to be desired.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #30
Old 09-23-2001, 11:43 PM
Man Man is offline
http://www.digido.com/ Look @ CDR Test Pages, Glen Meadows.
HTML code is On
Are the Bus Speeds for IDE cables always 133 mhz?? TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-13-2004 01:33 PM
CD BURN SPEEDS Dennis Scott Pro Tools TDM Systems (Mac) 0 01-07-2003 09:49 PM
Mac Superdrive speeds Andy Sneap Pro Tools TDM Systems (Mac) 9 07-17-2002 07:26 AM
Burning Speeds for Cd Audio ??? Gnosis General Discussion 51 05-10-2002 02:55 PM
DVD Transfer Speeds Zep Dude Pro Tools TDM Systems (Mac) 1 10-23-2000 03:38 PM
