S1 Fader Doesn't Work
All,
I have an S1 that I purchased (new) less than two months ago. Up until today I've been actively using all eight faders for a session I'm working on in Pro Tools 2021.10.0 and for no known reason Fader 4 doesn't register any moves I make with it while it is attentioned. Solo, Mute, Automation and Pan work fine. This seems limited to the actual fader. Has this happened to anyone before? Could I have accidentally done something in Control that I'm unaware of? Thanks in advance for your time. Last edited by Mixmaster Rick; 12-18-2021 at 10:42 PM. |
Re: S1 Fader Doesn't Work
Update.
I just attentioned the channel (4) that the fader doesn't respond to and using my Avid Dock it does in fact respond. This would mean that mechanically it does work correct? However in EuControl Settings, under Assign, I changed that channel from the default of Auto Assigned to Attentioned Track then I attentioned another track in my session and tried to change the volume using the S1 and nothing happened. This leads me to believe it is broken. Can anyone help? Before I try to have this replaced from Sweetwater I want to make sure there isn't something else I missed. Any ideas? Last edited by Mixmaster Rick; 12-18-2021 at 10:43 PM. |
Thanks for the response. I've already reached out to my Sweetwater Sales Engineer.
I'm having a similar issue as well. Fader works but it really stiff when moving it. Had mine only a little over a week. Waiting to hear back from Sweetwater as well.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Try taking the Fader cap off and simply put it back on. That worked for me except it happened again so I repeated the process and it's worked so far. My Sales Engineer just got back to me waiting to see if I want to swap it out. I've read other posts about this issue and someone commented that "Avid is aware of this issue". That doesn't make me feel too great since I'm about to get a second S1; I have a Dock as well.
Let me know if Sweetwater helps you out.
Same issue here. I bought my S1 10 months ago and the problem started after 5-6 months on CH1 and now CH6 makes the same unresponsiveness.
I need to power cycle or unplug & replug the Ethernet cable to make it work as normal. After a while like 20 minutes same blues again. Avid created RMA for me and calls the unit back for repair / swapping. I am working everyday, so I need my controller everyday. I am still trying to figure it out with static IP, turning off the Wi-Fi etc. But I think I’ll send it. Ultimate 2022.7 / Mac Studio M1 Max / Monterey / Latest Eucon Vers. |
Pre fader metering during recording, doesn’t work [solved] | Mattian | macOS | 1 | 04-25-2018 11:37 PM |
Eucon 3.1 bug with McMix: Shift-Fader doesn't work | DhyanMikael | Artist Series | 5 | 12-24-2013 04:50 AM |
MC mix fader doesn't respond to touch | Neale Eckstein | Artist Series | 3 | 01-05-2011 09:44 AM |
Fader doesn't work | Punx | MIDI | 1 | 04-11-2003 08:44 PM |
Midi Fader Doesn't Work? | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-11-2003 04:50 PM |
