Old 12-28-2019, 01:09 PM
jacksbyrne jacksbyrne is offline
Default Pro Tools/ Logic Pro X MIDI Issues
Hey gang! Got an issue that's cropped up with MIDI not being accurate between Logic and Pro Tools. Done some searching/googling, but I've had no luck so I thought I'd post, see if anyone's come across this before.
I work as an editor for a producer local to me that works in Logic. He'll send me drums to fix up as audio, along with a tempo map from a MIDI file if need be. I'll get them in time, then use DRT to generate MIDI notes for the kick and snare, and go through and align them by hand. I'll then print short audio spikes from that, check they're aligned, and send it all back to drop into his session. MIDI triggers samples using Slate Trigger (more accurate for phase than audio is) and the spikes will sometimes trigger gates or expansion, depending on what he needs.
Recent session, the MIDI isn't lining up once it gets back into Logic on his end. It a full album in one session, so the tempo map changes throughout. Doesn't appear to be a consistent drift, though I'm trusting what he's said for this to be the case. As far as we know this hasn't come up before, though it could just be the first time that it was bad enough for us to notice.
I've included a couple of screenshots, one from him, one from me, hopefully they make sense, but I can try and explain them if needed.
I don't know what information you'll need from me, so let me know if you need anything else to help and I'll do my best!
96khz MTC Midi Sync Issues (to Logic Pro X) Duff Man Pro Tools 11 0 05-30-2015 02:05 AM
Importing Midi data from Logic results in strange issues The Saxplayer macOS 5 05-28-2013 08:50 AM
pro tools installation causes garageband/logic issues chris4peeps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-15-2008 06:51 PM
Pro Tools 6.9.2 -compatibility issues with Logic 7 couchhome Pro Tools TDM Systems (Mac) 1 12-18-2005 10:41 AM
Logic Audio w/ Digi001- Midi issues Kraddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-06-2002 01:35 PM
