Re: Automator Services for Pro Tools (Mac)
Hmmm.... if you wouldn't mind sending me the 'code/text' from your automator routine, as an example, I can probably lay this out....
I've got a little experience in programming basic, visual basic, and VBA ..... nothing on the mac side, but this isn't exactly programming, and the concept is still the same.....
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
It also takes care of things like creating the Track Presets folder when the user didn’t create one before. It also changes the file extension so that you can load the saved file as a preset plus a few more little things. And since the Track Preset feature is already a working feature in PT, even though not documented yet, one can automate it. Its possible to automate the process of opening the Setup/Peripherals window and selecting the MIDI Controllers tab. Automating the several settings in the pop up buttons is pretty tricky and would be a custom job depending on your settings etc. |
I see Well, I'm still crossing my fingers that Avid will add this someday
Hi Oliver.
Nice job! Thanks for posting this. Is there a way to modify these scripts, so that I can chose which folder the presets are saved into? It would be nice to be able to sort the presets into folders. I don't really know how to use Automator. I tried to open up your script, but that did not seem to work... |
Awesome! Do you have any other interesting PT macros up your sleeve?
Then one which saves a session copy with checkbox “Audio Files" checked (as I always include all audio files with my copies) or one that selects unused clips in the session and removes them including clearing the undo queue, all in one go. Since most of them are tailored for my personal needs I am not sure if it justifies the extra work to make them “public compliant”, adding all kinds of checks and error dialogs in case the user does something odd etc. This stuff is pretty time consuming. But I am probably going to release a set of those that launch AudioSuite plug-ins, incl. the ones that process and close the AS window automatically. We’ll see. |
That sounds really cool, Oliver. I am very interested in this but as I said, I haven't really had the time to get into Automator yet. I am working professionally in post-production (sound design and re-recording mix of animation), and I am always looking for ways to optimize my workflow. I saw the video of the Slate Raven, where he shows a bunch of macros programmed into soft buttons. I was really inspired by that, and I am thinking that it must be possible to do pretty much the same thing with automator + for example Actions for iPad. It would be really cool to have a macros-controller with direct access buttons on a screen like that.
I tried some macro programming with Keyboard Maestro but it seemed hard to make it do exactly what I wanted. For example, I could not find a good way to make it wait for processing to complete before starting the next task, which made multi task macros not work. I tried to do a 'Consolidate all tracks and then export as files', but it did not really work because of this. I also tried QuickKeys. I could not make that work at all. I guess automator is a better programming tool for these kinds of things? Then I stumbled upon this thread. I understand that you are hesitant to be service responsible if you release these macros publicly. But would you be willing to share these with me? No responsibility on your side - I won't bother you, I promise ;-) And also, would you be willing to share the code with me, so I can 'open up' the macros and see how they are done? That would be invaluable knowledge for me to move on with me own programming. I hope this is not to much to ask. But I haven't really been able to find a whole lot of info and examples on macros for pro tools, so I am a bit in the dark about how to move on with this... |
The reason I picked Automator to share these actions is that using it is quite convenient since Automator app is part of the core apps in OS X and there is no need for extra tools to use Automator Services, shortcuts can easily be attached to Automator Services, too. Basically the Automator stuff consists of 2 parts: The Automator Service which you can attach a shortcut to and the Automator Action. The Action holds the entire code and is being triggered by the Service. 98% of the code in my actions is plain AppleScript, plus a little bit AppleScriptObjC and some extra lines of code to make it work in Automator. Automator Actions are created in Apple Xcode while the AppleScript code itself can be written in any AppleScript compatible Editor like Apple’s own Script Editor or Script Debugger from Late Night Software. I am actually thinking about to not use Automator anymore because it is hard to debug Automator Actions and they are not easy to maintain either. Plain AppleScript Bundles would be more handy, way faster and more reliable but users will have to use tools like FastScripts, Keyboard Maestro, Quicksilver or the like to actually trigger (fire up) the Scripts. If you want to learn how to create such Scripts or Automator Actions you gotta learn AppleScript I am afraid. Maybe the newly introduced JavaScript in OS X could be useful, too. I am not a programer, I learned this by doing over the years or by hiring someone else when things got too complicated. All this stuff is achieved with GUI scripting as PT is not scriptable, its a lot of trial and error really. Oliver |
Thanks for the explanation. I might check out AppleScript although it seems a bit intimidating. Or try to get some help. Thanks.
Task automator for windows similar to apple's automator app | John_Toolbox | General Discussion | 3 | 02-02-2010 05:41 AM |
I want the PRO TOOLS M-8 services, I M-AUDIO | M.SADIQ ADEL | Pro Tools M-Powered (Win) | 5 | 09-07-2009 10:17 AM |
Pro tools LE and "Best Services" Plugins | TDas | Virtual Instruments | 3 | 05-11-2006 12:11 AM |
Automator with ProTools? | nelsonmuntz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-09-2005 07:47 PM |
Automator | Tweakhead | Pro Tools TDM Systems (Mac) | 1 | 07-31-2005 07:20 PM |
