Re: Pro Tools LE on new MacBook Pro I7
I registered just now because I am having the same problems on my 15" i7 Macbook Pro and hope to find a solution alongside anyone else having issues.. I use the Mbox 2 without PT so I installed the standalone driver for snow leopard. Upon installing, setting my IO settings to the mbox (both in system prefs and audio midi setup) results in 1 second of system audio before completely dropping out, stalling, freezing the computer until I unplug the mbox from the laptop. If I shut down my computer at any point after the mbox stalls and has to be unplugged, the computer kernel panics. Basically, the minute I plug in the interface the system locks up. Has anyone found any tricks to fix these issues? I don't even get the chance to open up iTunes or Logic to test the interface before it freezes on me.
I'm not having any problems with PT LE 8.0.3cs2 with the new macbook pros.
Ive got the 2.66ghz i7 15 incher. running with a mbox 2. no crashes so far... but i do have a problem running multiple sound sources outside of protools. ie. if i play a song in itunes and play a movie in vlc player. it stutters (like an infinite delay) until i shut one off. sometimes i have to unplug the interface to get it to stop. Anyone else have these problems? Edit: make sure you guys arent using the prerelease versions of PT. had a lot of problems with the prerelease versions with kernal panics/crashes and freezing. (the splash screen while loading PT has changed to the Avid logo) |
Are you using the normal USB MBox 2 or the MBox 2 Pro? I believe the problem in an incompatibility with the USB ports used by the i5/i7 chipset. I ran into the same problem with the i5 and i7 iMacs. I was able to get it working by plugging the MBox2 in through a powered USB hub, but the results are inconsistent. |
I have just plugged in my new Mbox 2 Pro, and NONE of the problems described earlier (by me) now occur.
Everything seems to be working like a gem so far. So apparently all bugs are related to the usb-powered devices (m-boxes). |
good to hear it.
PT9, Zed R16 & Macbook Pro i7 2.66Ghz |
I wonder if the future usb3 will be so fine. Somehow, over the years I really learnt to hate usb devices.
my blog:Tamas Dragon |
I'd better keep an eye on this post, 'cause I was planning to get rid off my MacBook Pro (early2007) and get a new MacBook Pro I7... guess I'll have to wait for a solution for this incompatibility with the mbox usb devices...
Bummer... |
I think this is related to the power offered by the USB ports on the new MacBooks. I have spent the day trying to get my M-Box 2 working on my new MacBook Pro i7 (OS 10.6.3), and could only get it to work when using the front USB port. In the rearmost port, PT would fail to start, and the system would lock up etc etc. With it plugged in to the front port though, it works fine.
I have read elsewhere that there are significant differences between each port. As such, I now have a powered hub plugged into the front port, and use this for the M-Box connection and a few other things. I then have my steinberg license dongle plugged directly into the rear port, and everything is working fine. If I try to plug anything into the remaining USB port on the MacBook however, the above problems return. |
I tried using different USB ports on my MacBook pro i7 to no avail. I then tried plugging into the USB hub, no workie. THEN I tried removing the core audio files to reinstall the driver and MY HARD DRIVE CORRUPTED And I had to reinstall a clean osx after formatting the drive.......I guess it's time to update my audio interface.
Okay. I hope this helps.
I was able to reproduce the issue on the new i7 MBP. (15 incher) For me, this problem only happens when i plug my Mbox 2 into the usb port further away from me (closer to the charging port). There are no problems with the usb port closest to the sd slot (closest to the user). Can anyone else confirm? @xlr231: I am using the regular USB Mbox 2. try plugging it in the usb port closest to you. |
macbook air 2 gb ram-which pro tools ? | ana23 | macOS | 2 | 07-10-2013 08:48 AM |
Which MacBook Pro to get for P Tools. | WernerF | macOS | 11 | 07-23-2012 04:55 PM |
Pro Tools 8 and MacBook Air | Moviesound | Post - Surround - Video | 3 | 08-23-2011 08:20 AM |
Best way in to Pro Tools on MacBook | fhrussell | Pro Tools TDM Systems (Mac) | 7 | 07-18-2010 05:59 PM |
Pro Tools LE 7 with MacBook | Dre aka Producer G | Pro Tools M-Powered (Mac) | 1 | 07-06-2006 05:02 PM |
