#6671
Re: i7 Builds - Specs and Results
Good Day
I really hope someone might be able to help, I am at my wits end trying to get PT to play ball with my system. I am encountering endless CPU Spikes leading to 9093 errors and its driving me crazy. I am getting errors in all versions of pro tools (10,11 and 12.4) on nearly all buffer sample sizes on both windows 7 and 8.1. I have tried every conceivable hardware configuation I have available to me as well as done every optimisation on the avid force page, also trash pref etc. I am running via HD Native on an ASUS Z170M-PLUS with Intel i7 6700 3.4khz and 16GB DDR4 RAM, it should be able to handle PT. My old Core2 quad performed better with less than half the RAM. Here is a detailed spec of my PC, if anyone can help I would forever be in your debt: Model : OEM System Product Name Serial Number : System Ser********** Chassis : Default string Desktop Mainboard : ASUS Z170M-PLUS Serial Number : 1507490******** BIOS : AMI (OEM) 3301 02/10/2017 Intel vPro : 11.08.50.3399 Total Memory : 16GB DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (4C 8T 3.41GHz, 3.4GHz IMC/4GHz, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1151 Chipset Memory Controller : ASUS Core (Skylake-D QC) Host Bridge/DRAM Registers 100MHz, 2x 8GB DIMM DDR4 2.13GHz 128-bit Memory Module(s) Memory Module : Kingston/Hynix (Hyundai) KHX2133C14D48G 8GB DDR4 PC4-17100U DDR4-2134 (14-14-14-35 4-50-16-5) Memory Module : Kingston/Hynix (Hyundai) KHX2133C14D48G 8GB DDR4 PC4-17100U DDR4-2134 (14-14-14-35 4-50-16-5) Video System Monitor/Panel : ACI VG248 (1920x1080, 24.0") Monitor/Panel : ACI VG248 (1920x1080, 24.0") Video Adapter : AMD Radeon HD 7700 Series (8CU 512SP SM5.1 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit, PCIe 3.00 x16) Video Adapter : AMD Radeon HD 7700 Series (8CU 512SP SM5.1 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit, PCIe 3.00 x16) Graphics Processor OpenCL : AMD Radeon HD 7700 Series (512SP 8C 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit) D3D 11 : AMD Radeon HD 7700 Series (512SP 8C 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit) OpenGL : AMD Radeon HD 7700 Series (512SP 8C 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit) OpenGL : AMD Radeon HD 7700 Series (512SP 8C 800MHz, 16kB L2, 1GB DDR5 4.5GHz 128-bit) Storage Devices Crucial_CT128M550SSD1 (128GB, SATA600, 2.5", SSD, OPAL, SED) : 119GB (C:) Samsung SSD 850 EVO 500GB (500.1GB, SATA600, SSD, OPAL) : 466GB (D:) SAMSUNG HD204UI (2TB, SATA300, 3.5", 5400rpm, 32MB Cache) : 2TB (E:) Logical Storage Devices System Reserved : 350MB (NTFS, 4kB) @ Crucial_CT128M550SSD1 (128GB, SATA600, 2.5", SSD, OPAL, SED) Data & Docs (D:) : 466GB (NTFS, 4kB) @ Samsung SSD 850 EVO 500GB (500.1GB, SATA600, SSD, OPAL) Libraries (E:) : 2TB (NTFS, 4kB) @ SAMSUNG HD204UI (2TB, SATA300, 3.5", 5400rpm, 32MB Cache) Hard Disk (C:) : 119GB (NTFS, 4kB) @ Crucial_CT128M550SSD1 (128GB, SATA600, 2.5", SSD, OPAL, SED) Peripherals LPC Hub Controller #1 : ASUS Z170 Sunrise Point-H LPC Controller Audio Device : ASUS Sunrise Point-H HD Audio Audio Device : AVID Tech HD Native Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS Sunrise Point-H SATA controller [AHCI mode] Disk Controller : ASUS Sunrise Point-H PMC USB Controller #1 : ASUS Sunrise Point-H USB 3.0 xHCI Controller SMBus/i2c Controller #1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Pantum P2200W Series (1200x600) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet) Network Adapter : TAP-Windows Adapter V9 (Ethernet) Wireless Adapter : Qualcomm Atheros AR9287 Wireless Network Adapter (802.11n (HT), AES-CCMP, 144.4Mbps) Operating System Windows System : Microsoft Windows 8.1 Personal 6.03.9600 Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#6672
I received an 8700K machine built by Pro Tools PC. In a word. Wow!
I'm enjoying improvements on every single front, not just performance. Even ear fatigue, of all things. That 8700K, though. Man oh man, is it ever smooth and quick. VERY responsive. |
#6673
^^ This ^^
#6674
Ehh, how does it help you against ear fatigue? |
#6675
32MB DDR4 2400 RAM 8700K LGA1151 @3700gHz (stock) and set to 4400gHz (partially overclocked) and one more BIOS setting away from 4700gHz should I need it. System and Audio drives are both 500gb Solid State Two other drives are WD 2TB Machine noise and the loss of some awful hi-mid sound degradation are the two factors on ear fatigue I will commit to. I noticed decreased pain factor in all audio - mine, VI or ripped from CD - right away. I was not expecting that. Addition by subtraction is in play here, for sure. (the subtraction being my old machine.) However, at some point, I have to tip my hat to the design and implementation of the components in the new machine. Does anyone know (or care to guess) to what extent, if at all, Avid adjusts audio in real time to enable lower powered machines to run? I've read little bits and pieces here and there, but nothing concrete. More like some generic advice in the reference guide in relation to topics like setting memory cache, etc. |
#6676
To Barney1981- The chipset might be the issue. AFAIK, Z170M-PLUS is an unknown for compatibility. Additionally, why Windows 8.x??? I'd say moving to 10 is a no-brainer at this point. Lastly, running samples off a 5400 rpm drive is maybe not a good idea. Another SSD would be ideal, but just moving to a 7200 rpm drive couldn't hurt
"Does anyone know (or care to guess) to what extent, if at all, Avid adjusts audio in real time to enable lower powered machines to run? I've read little bits and pieces here and there, but nothing concrete. More like some generic advice in the reference guide in relation to topics like setting memory cache, etc." PT doesn't "adjust" anything. Either your computer can handle the workload or it can't. Adjusting the playback buffer higher will lighten the load on the system(at the expense of more latency). There's plenty of info on the DUC, on Sweetwater's site and all over youtube for tweaking a computer to maximize performance
#6677
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#6678
No, not worried at all. Just curious about any possible effects it had on the ear fatigue front as the improvement was big and obvious. It appears that my old machine did me no favors with both ambient and signal, audibly speaking. I do NOT miss that whistling things in the signal nor in the room. Thanks for the memory tip. @Albee152 - Thanks for your reply. Curious, as always, I found what I had read in the PT reference about performance and effects. It was only concerning automation rendering as system usage got close to maximum. (pg 102 - actually, that whole last paragraph is rather ambiguous...which really doesn't matter, either, except that helped fuel the curiosity. ) |
#6679
BTW, for me, -9093 errors almost completely go away as soon as I disconnect the network cable from my main internet switch
#6680
Running which version of PT?
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
