Digi002 Rack - send analog inputs through ADAT out?
Is it possible to setup the Digi002 to pipe the analog input signals direct through to the ADAT out?
Re: Digi002 Rack - send analog inputs through ADAT out?
You mean use it as a a/d converter? You can, but not without a computer to do the routing. And you would also have some latency.
Hope it helps Pepo |
yes, I am aware that I can set up busses for the routing in software. I wanted to make the Digi002 act as an ADAT "slave" to another hardware device, but since I cannot directly route the analogs to the optical out through the hardware without introducing latency from external programs, then, unfortunately, it is not a feasible option in my situation. Thanks for the reply
DIGI002 ADAT inputs - 96k? | roryrok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-16-2014 10:05 AM |
HD I/O use 16 analog inputs plus 8 adat??? | ZeDave | Pro Tools HDX & HD Native Systems (Mac) | 2 | 08-24-2012 01:26 PM |
Adat plus analog inputs | CeeBee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-24-2007 06:40 AM |
ADAT for additional inputs for Digi002??? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-21-2004 03:33 PM |
extra ADAT interface analog inputs for 001? | voltech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-05-2002 03:44 PM |
