Least expensive HD upgrade path?
I have Pro Tools 10 (not HD) with the Complete Production Toolkit. I'd like to get up to date. Avid offers an upgrade path to 12HD, but it's a thousand bucks! That's more than I want to pay for something that won't be generating any income. I'd just use Vanilla, but working in 5.1 is an absolute requirement.
Do any of you know of a less expensive way to go from what I have to 12HD? Or is there an add-on (like the old CPTK) that will provide 5.1 capability with Vanilla? Thanks 1,000,000! |
Re: Least expensive HD upgrade path?
No other way to get to HD12 unfortunately and no add ons either.
$999 is the going rate at the moment. There was an offer last year for several months and avid said it was the last chance to upgrade with a CPTK 1/2. To a HD11 or it could have been HD12 cant recall. Sorry.
IIRC there is a workaround to do 5.1 with PT Vanilla. Do a search as that comes up from time to time.
There was a CPTK to HD cross/up grade to PT11HD, which was $600, and then you are locked into HD support/upgrade path @ $400 year - so you would actually come out ahead of those of us by paying $1K now...
5.1 in vanilla involves complicated bussing - which works, but is still a work around... |
I wanted to buy it when it was $600, but the Avid Video Engine wouldn't work with my computer (didn't work with "certain" Macs, including mine). Now I have a new Mac but in just 14 months the price to get back the features I had before has ballooned to $2200! I'd just keep using 10, but it doesn't work with any recent OS and there's no way to install an OS old enough to work on this new machine. At that price I could just buy Nuendo and wave a middle finger at Avid on my way out the door. |
I can feel your pain, it's unfair to treat you different than a standard hd user. Nuendo is an option if you're in audio post.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
The Avid store is not the all defining way. Check with a reputable "Music store" They have paths you can utilize.
IMDB |
linkedin
No other choice but to save £1200 needed for a full HD licence. But that's what I'm doing. HD for post production is absolutely essential. The work around for 5.1 isn't worth the hassle and you still can't pan it properly and 360 degree reverb isn't an option either. It's not just surround though. Field recorder guide tracks is a critical feature too, you can't do that in Nuendo. Unless you paid a whopping £1500 for Titan software.
You missed the opportunity to upgrade from cptk to HD a long time ago. That was something they offered for a limited time to cptk owners when they dropped support for it. Last edited by melloj; 03-15-2017 at 10:08 AM. |
PT10 isn't officially supported, but it should work fine - as far as I remember, the only issue is it's a bugger to uninstall, should you need to (had to be done manually). PT12 can be co-installed with PT10, should you end up buying it later down the line. Sent from my iPhone using Tapatalk |
Is there any upgrade path from PT HD8? | Ru_C | Pro Tools 12 | 9 | 04-17-2015 10:11 AM |
PT 11 HDX upgrade Too Expensive right now | Avgerinos | General Discussion | 14 | 06-19-2014 10:21 AM |
Just upgrade from PT9 to 10 : No perf improvement: not worth 299$ too expensive !!! | klyg | Pro Tools 10 | 20 | 10-31-2011 06:09 PM |
7.4.2 to 9 upgrade path... | pidge | Pro Tools TDM Systems (Mac) | 3 | 11-06-2010 04:08 AM |
HD Upgrade path | Chris Lambrechts | General Discussion | 15 | 01-24-2002 04:37 PM |
