Old 12-23-2013, 09:34 PM
justus1900 justus1900 is offline
Default Pro Tools 11.1.0 AAE-9173 Error
Installed Pro Tools 11.1.0 and now none of my older sessions will play, As soon as the session loads my CPU Meter goes to 100% no matter what buffer rate. These are sessions that would play at 64 buffer rate in PT11.0.2 will not play at all? Any else having this issue after this PT 11.1.0 update?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 12-23-2013, 09:52 PM
Default Re: Pro Tools 11.1.0 AAE-9173 Error
Restarted sessions with "Shift" button hit and started "Make Active" on my Plug-Ins one by one and its the "AVID MasterMeter" that is making my CPU Spike to 100%. Once I removed that from my sessions they all play fine now. So there is some kind of bug in the AVID MasterMeter in Pro Tools 11.1.0.
Main:
JBL LSR4328P 8"
Old 07-01-2014, 01:51 AM
FLi's Avatar
FLi FLi is offline
Had the same issue but I find its with the SansAmp-PSA plug. It works for a bit and then it just goes mad and chews up CPU. Disable it and everything runs smoothly again.
Old 07-01-2014, 04:59 AM
Pro Tools 11.2 MasterMeter no longer causes CPU usage spikes. (PTSW-193401), Bug Fixed, Thank you
Main:
JBL LSR4328P 8"
Old 12-22-2015, 02:46 PM
TeeMade TeeMade is offline
Default Re: Pro Tools 12.3.1 AAE-9173 Error
ERROR STILL POPPING UP ALL I USE IS NATIVE INSTRUMENTS SMH and i have HD its happened 4 times in a session which is an improvement never the less a big situation as far as performance hd is suppose to be at prime performance PLEASE FIX
AAE - 9173 cpu overloads in pt11 vs pt10 Carbon 2501 Pro Tools 11 0 03-07-2014 09:22 PM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
i7 Macbook Pro - 11.0.2 / 11.0.3 constant -9173 errors A Chapman macOS 13 12-18-2013 09:36 PM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
