Re: How to select output device
Make sure the sample rate is set the same for your adio devices. Even though you set a sample rate for new project in PT, all of your connected devices may not follow. I suspect your speakers are connected to a pair of outputs on the device that's not set at the same sample rate.
It's already been said to default the outputs but I go a step further and delete them and then default. I'd also do the same for the busses. Hope one of these solutions works for you! |
Listen to the weed!! Im surprised no one said anything before but you have to turn on input monitoring to hear your record enabled track!!! i.e. The green light on the transport under the red light just click on it
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
"No output device selected in Studio Monitor Express, using Default Output"?? | Focuret | Pro Tools 10 | 4 | 01-11-2014 02:31 PM |
getting my G4 select 001 as my output source | jacobsapple | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-29-2009 05:27 AM |
can't select the mbox as an audio input device | Markus Mehlau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2007 07:59 AM |
How do I select multiple output paths? | syra | Pro Tools TDM Systems (Mac) | 5 | 10-21-2003 12:39 AM |
