Can't Open Session- "because Pro Tools could not set Sample rate to specified value
Everything says 88.2 My console, my firewire driver, and my MIDI setup all show 88.2K. The same error occurs if I try to create a new session in Pro Tools. This error is only on opening my existing sessions. And now it also is telling me there are no DigiCards.
What's Up?? I only upgraded to allow for PT11, otherwise everything was working fine. I already deleted databases, prefs, etc. Made no difference. EVERYTHING WORKED FINE WITH 10.3.5 Tascam DM-4800 Firewire 400 Pro Tools 10.3.6 OSX 10.8.4 |
Re: Can't Open Session- "because Pro Tools could not set Sample rate to specified val
Could be your Tascam. Can you change interfaces and see of you can set the sample rate then? What if you try a different rate? What happens then.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I tried restarting the Tascam. It is set to 88.2, I verified my firewire interface and it was also LOCKED at 88.2, even the MIDI setup on my MAC verified that it was 88.2K and I am using the Firewire as the interface. If I used the Pro Tools Aggregate, then it starts looking for Digidesign cards, which I don't have. So I use the Firewire MKII interface choice within the MIDI setup.
I can play anything from my files and it passes properly, it's only when trying to open or create new sessions. Even when I try to create a new session in PT, it defaults to 88.2K, but when it is time for it to create the actual session and write it to the hard drive, the error pops up that it could not set the sample rate, ever though it was set already with all the hardware. |
Can you change the sampling rate by using the System Preferences Control Panel? It's at the bottom under "Other". I have a control panel for the 002, I don't know if you have one for your driver.
Was the only change the update to 10.3.6? Did you re-load any drivers?
And you are you have the playback engine set to the correct interface?
Did you reinstall the device driver? If nothing else I would try uninstalling that and reinstalling again. |
"Pro Tools could not set sample rate to specified value" error with MadiXtreme | redbull | Windows | 2 | 08-26-2012 09:45 AM |
Can I open a session at a different sample rate? | benherron.rrr | Windows | 5 | 04-13-2012 03:49 AM |
Word Clock Issues "the HW device is at a different sample rate from the open session" | daveseviltwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-11-2011 06:09 PM |
Mytek + The HW device is at a different sample rate from the open session | glynnp | macOS | 2 | 10-20-2011 03:53 PM |
HW device is at a different sample rate from the open session | bad jitter | Pro Tools 9 | 2 | 08-16-2011 11:36 AM |
