Old 03-13-2003, 02:31 PM
Cali Hendrixx Cali Hendrixx is offline
Default is there latency using midi time code or midi clock(im new)
i know using the mbox and doing overdubs with vocals your gona get around 164 samples of latency something around there but i wanted to know if i was gona use the mbox with my mpc and my midi sport 1x1 and use midi time code or midi clock should i look for latency in my tracks or should they all line up and play all on beat. im stil new with pro tools but i wanted to get a answer about this before i get started.
P.s. all im tring to do is just take all my tracks that are in the mpc and put them on its own track in pro tools using the mbox and a midi interface. so i want to know if doing this will my track still be off once i play it back.
Hey man im just tring to get a grip on this stuff!
Old 03-13-2003, 02:36 PM
Default Re: is there latency using midi time code or midi clock(im new)
MTC itself is only quarter frame accurate which is about 8.3 msecs. I've also never had good success getting the MBox to sync correctly with SPDIF and MTC.
You should match your MIDI global offset in the prefs to the buffer size.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-13-2003, 03:24 PM
you lost me on the midi global offset but i know i will learn it when i real up to that point in the booklete but if you can give me a lil info on that
Old 03-13-2003, 03:28 PM
In the Playback Engine dialog (Setups->Playback Engine) write down the buffer size.. for example 512 sample. Now go to Setups->Preferences and the MIDI tab.. and in the setting Global MIDI playback offset enter the same value as a negative value (-512).
Rail
Platinum Samples
Old 03-13-2003, 04:14 PM
ok i just did everything you said and i saved it. so this will keep all my tracks in sync right.
Old 03-13-2003, 04:28 PM
No guarantees.. but it'll help. I personally think the MBox still needs some work with regard to sync issues under XP.
Rail
Platinum Samples
Old 03-13-2003, 04:50 PM
well im just gona have to see hot things line up and sound then....thanks anyways
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
Midi Time Code (MTC), or Midi Beat Clock David Lawler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-22-2005 09:22 PM
is there latency when using midi time code or midi clock(im still new at this) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-15-2003 10:18 AM
is there latency using midi time code or midi clock(im new) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2003 02:32 PM
MIDI Clock vs. MIDI Time Code thopman Tips & Tricks 2 06-20-2001 05:01 AM
