2022.12 copy/paste clips broken
Anyone else have this?
Copy / paste audio clips does nothing. Happens on both of my systems (M1 MacBook Pro and M1 Mac studio) I found a workaround, toggle mix view - back to edit view (2 x shift-command-0). After that it works, but then if I do anything else after copy-paste, it's broken again. Running PT on Rosetta mode. |
Re: 2022.12 copy/paste clips broken
I've had the same issue pop up for me (randomly) too. I cannot pin what causes this, its usually late into a session and copy/paste will no work. Command-C/Command-V as well as Edit > Copy / Edit > Paste do nothing!!
Very frustrating for such a basic operation to be broken. Option-Dragging a clip will work and has been my work around but is not suitable when you need to move a clip more than a few minutes down the timeline. Please look into this Avid!!! Also 2022.12, M1 12.6.2
leaving the world a better sounding place |
Can report same issue here on Intel iMac - only workaround in 2022.12 I could find was that you can use "C" and "V" without the command key and it'll copy and paste - but it was such a flow killer (muscle memory being what it is) that I rolled back to 2022.10 which doesn't have this behaviour.
I have observed that, if the "Clip Effects" tab is visible, the normal CUT and PASTE commands do not work with automation data, etc...
I experience this randomly on my system as well. I usually close the session and re open it.
FWIW, I always have my clip FX tab open.
Neotech Concepts http://www.imdb.com/name/nm0235036/ ! sonic gymnastics for the illusionary arts ! 2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch, EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB |
Exact same issue here with 2022.12 an cut and paste. It only seems to happen when Clip Effects window is open. When I close it, cut and paste work normally again. Pretty big bug I hope is addressed soon.
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
Regex in 2022.12 VERY Broken | NateAlexander | Pro Tools | 1 | 02-09-2023 01:03 AM |
Latest Pro Tools (2022) pitch variations and copy/paste | timtech | Pro Tools | 0 | 09-18-2022 09:18 AM |
Copy... Paste... Paste... Paste...? | accession | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-18-2022 04:18 PM |
Copy works paste doesnt paste??? | SoMedia | Pro Tools M-Powered (Win) | 12 | 01-04-2011 01:19 PM |
Shuffle doesn't shift volumes - copy & paste doesn't copy automation | marcnyc | Pro Tools TDM Systems (Mac) | 2 | 03-12-2010 12:46 AM |
