Audiosuite Rendering = lost waveform
This only happens to me here and there, and I am not sure what causes it. There are times when I import a stereo piece of audio, then drag it into my session, then, when rendering with Audiosuite, the clip's waveform disappears and the audio is also gone.
If I hit Z, it will undo, and be fine. Even some other tracks render it ok, which is odd. But, I am sure this is not normal, and I am guessing that there is something on my setup that needs to change? Or is it simply a memory issue? I use PT 12.5 on a late 2012 iMac, with a Digi 003 rack. 90% of the audio I work with is imported into my sessions. Any suggestions for this PT veteran who suddenly feels like a noob? lol Thank you! (Ignore my old signature - my info is here) ProTools 12.5 Mac OSX 10.11.6 2012 iMac. 3.5Ghz Intel Core i7 Memory: 32GB 1333 MhZ DDR3 Digi 003r .
Regards, Chris ProTools 12.7 Mac OSX 10.12.2 Intel iMac 3.4GHz i7 (late 2012) with 32GB RAM Digi 003r |
Re: Audiosuite Rendering = lost waveform
2 things come to my mind.
#1-go into Preferences and check the option to "Automatically copy files on import" #2-to avoid misplacing audio, I will usually drag audio into the session folder and import it from there. Why I do this is because sometimes PT likes to bring in audio from its original location, and just reference it, while sometimes not actually placing a copy in the session's Audio Files folder Most of us get bit by this tidbit at least once As to why rendered audio disappears, that's a head-scratcher for sure, but make sure your Audiosuite plugin has the "Use in Playlist" button lit(in light blue)
Thanks - I am sorry for the delayed reply. I will do what you suggested and see if it helps.
Fades not rendering properly in Audiosuite ? | frenchman | Pro Tools 10 | 0 | 09-06-2014 02:33 AM |
Audiosuite Rendering Problem | pmcminn | Pro Tools 11 | 2 | 05-09-2014 06:18 AM |
Losing Audio Data and Waveform Rendering Issues | nathanaelj83 | Pro Tools 10 | 4 | 10-08-2013 02:59 PM |
why is audiosuite rendering to region list and not to edit window?? | luts | macOS | 1 | 06-28-2012 12:21 AM |
