  #51
Old 05-14-2020, 04:18 AM
Freechess Freechess is offline
Default Re: Artist Mix: Pan knob not functional
Originally Posted by ProphitCity1111 View Post
Hey im having the same problem with my Avid Artist Mix. Pan Knob 1 dose not work properly when using it to adjust settings and also hardware test shows the touch function is not working. Only on pan knob 1 everything else works to my knowledge. Did anyone on here ever come up with solution or anything worth mentioning about this issue?
Easy solution that worked for me - after having exactly the same frustrating problem:
I pulled off the pan pot and blew out the dust with an air pressure spray. TOUCH worked again, done. Hope that helps someone...
  #52
Old 10-30-2020, 08:37 AM
Schottlandru Schottlandru is offline
IT DID HELP, thanks!
I didn't manage to pull off the encoder (do they really come off of the Artist mix? Just pull (with force)?)
But some dust seemed to fall out and touch is working again.
THANKS!
  #53
Old 10-30-2020, 08:56 AM
THANKS!
Wonderful! Welcome back to happy mixing :)
Yes, you can pull them straight off - slowly with some force -, it's a bit like chewing gum
___
iMac 27" 2011, High Sierra 10.13.6, Pro Tools 2020.3.0, Artist Mix 1.5.6, UAD Apollo Twin + Satellite
Assignable knob on Artist Transport? asterix2k10 Artist Series 2 02-09-2016 11:43 PM
Feature Request (VOTE!): Linear Knob option for Artist Control jeremiahmoore Artist Series 9 04-21-2015 11:08 AM
Artist Control Monitor/Ctrl Room Volume Knob HowlingWolfStudio Artist Series 1 04-15-2014 11:10 PM
003 Rack+ functional but needs some love The Turnback Buy & Sell 2 08-16-2013 02:52 PM
Turn feature off on Artist Control knob. VSOP Studios Artist Series 17 04-11-2013 05:49 PM
