  #21
Old 04-18-2015, 02:33 PM
mesaone mesaone is offline
Default Re: Blue Cat's PatchWork 1.7 is here, with ext. sidechain input, aux outputs and more
Hey Blue Cat, you guys are awesome.
Have you considered making a panning utility like Goodhertz Panpot that has can control interaural level differences (like a standard pan control), interaural time arrival differences (like a Haas-style delay), and spectral differences (like Proximity)?
I think that would be awesome. It would be the perfect companion to your Gain Suite, Patchwork, and your analysis suite.
That would be amazing, and I'm sure everyone would buy it. It would help us all hold out until the Blue Cat DAW arrives.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #22
Old 04-20-2015, 08:21 PM
WernerF WernerF is offline
Maybe it's because I'm using P Tools 10HD but man, this is the buggiest plugin that I have ever used. I insert a VI and after about three minutes everything freezes. I mean everything. I usually have to force quit Pro Tools just to get things to function again. Anyone else seeing this?
By the way, the exact same VI's work just fine in Reaper ReWired into Pro Tools.
  #23
Old 04-20-2015, 09:09 PM
Glenjb Glenjb is offline
With pro tools 10 being a 32 bit app it can only access <4gb of whatever RAM you have. When you rewire VI's with Reaper into Pt10, Reaper is using RAM outside of that to run itself and those VI's.
  #24
Old 04-21-2015, 08:53 AM
Thanks for the suggestion. I'm aware of that limitation but the thing is that VI's like Serum run much better when instantiated in Pro Tools than when instantiated in Patchwork. Also, if I check the RAM usage that is occurring when the VI is being used the RAM usage is way below 4 gigs. I have 32 gig of RAM BY the way. Must be something else that is amiss.
  #25
Old 04-21-2015, 11:48 AM
Must be. Patchwork has been great for me. I use it to host MB7-2 in 4 band mode for multi-band compression and a brick wall limiter and soft knee clipper from IK Multimedia in Patchwork on the output of MB7-2 and no issues.
Jack
QAPLA!
  #26
Old 04-21-2015, 12:09 PM
Emcha_audio's Avatar
Personally I'm having a bug with a vst pluging from applsoft, don't know if it's the plugin itself (doesn't seem to be when I load it from cubase) but in pro tools 11 and pro tools 12, the plugin hosted in patchwork 1.7 has been freezing my sessions to the point I had to force the process to quit as the audio was still played but I could control nothing.
Manny.
Wave-T.com
  #27
Old 04-21-2015, 06:23 PM
Aha, the same thing is happening here. I think the fact that it's a VI that, as opposed to just a processing plugin, is being hosted is maybe the issue. That's why I'm curious as to whether or not someone else is seeing this behavior.
  #28
Old 04-21-2015, 08:44 PM
Well mine is definitely not a VI, it's apqualizr from apulsoft, one of the few eq's that you can set as many filters as you wish.
Manny.
Wave-T.com
  #29
Old 04-21-2015, 10:35 PM
bluecataudio's Avatar
bluecataudio bluecataudio is offline
Blue Cat Audio
Some plug-ins will indeed cause issues when hosted thru PatchWork inside Pro Tools (be it 10 or 11). While we have managed to bypass the limitations of many plug-ins, there might still be a few one that cause crashes or weird behavior. If can you send us the details by email, we can give those a try (but fixing the issue may require changes from their manufacturers).
  #30
Old 04-22-2015, 07:15 AM
Ok, thanks. I'll send an e-mail. One of the main offenders is Serum which, oddly enough, works better as a a Native plugin directly in Pro Tools than it does in PatchWorks.
HTML code is On
Blue Cat Patchwork & Cthulhu DonaldM Virtual Instruments 34 09-10-2017 03:26 PM
Blue Cat's PatchWork Updated to v1.62, with brand new Light Blue UI Theme bluecataudio AAX Plug-ins 5 01-10-2015 12:41 AM
Blue Cat Patchwork updated musicman691 AAX Plug-ins 31 07-07-2014 03:25 AM
Blue Cat - Patchwork ..., Update Ver 1.2 Seafoam_Green AAX Plug-ins 1 05-03-2014 04:54 AM
Blue Cat's Patchwork bug? Johnny Hulst AAX Plug-ins 4 04-08-2014 12:10 PM
