Old 08-06-2012, 02:42 AM
Ludicrous Speed Ludicrous Speed is offline
Default How best to A/B inside the box
Hi there,
Been a long time, I have searched around for suggestions on how to A/B inside the box & I am a bit stumped.
Could anyone offer a solution on how to instantly A/B between two sets of monitors using Pro Tools? I have an M-Audio FW 1814 & have one set of speakers on output 1/2 & another set on 3/4.
The thought occurs that there should be some simple way to do this within pro tools? I'm probably just missing something.
Thanks for any help you might offer.
Cheers,
- Ryan
Old 08-06-2012, 12:56 PM
Default Re: How best to A/B inside the box
You need to break down and buy a monitor switcher. SM Pro has a cheap one but i really like the Presonus Central Station.
Old 08-06-2012, 02:13 PM
cwsand's Avatar
cwsand cwsand is offline
You could set up 2 Stereo Aux channels and send your mix to both and set the outputs of one to 1/2 and the other to 3/4. You might also use an additional Master channel for both so you don't overload the aux channels. Then you'd have to mute/unmute each. The disadvantage is there would be a slight delay between switching between speakers while you move the mouse from muting one of the auxes to unmuting the other if you're working in the box.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-15-2012, 11:42 PM
Old 08-16-2012, 02:38 AM
chrisdee's Avatar
chrisdee chrisdee is offline
With Windows + Alt you can assign multiple outputs from each channel. First select output 1-2, then hold down Shift + Windows + Alt and select 3-4.
Then assign one master fader to each output and mute/solo to A/B.
Old 08-17-2012, 12:28 AM
cwsand's Avatar
Actually you have to mute/solo on Aux tracks since Master Faders don't have mute or solo buttons.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 08-20-2012, 01:55 PM
chrisdee's Avatar
You are right. Sorry about that.
Old 08-31-2012, 10:33 AM
cwsand's Avatar
I found a better way to do this so that you don't have to use the mute buttons - Go to Options-Solo Mode and choose X-OR. This way, you can just click on another Solo button and the original solo will be cancelled when the new one initiates. Gives you an instantaneous A/B comparison.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Digi 003+ Mod Inside fezriel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-21-2017 12:00 AM
wny do i need sp2 on xp? see inside please amore125 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-14-2007 12:27 PM
Bouncing INSIDE or OUTSIDE the box? minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-14-2005 12:28 PM
Think inside the box L.A.Branville Pro Tools TDM Systems (Win) 4 01-07-2005 08:45 AM
OT: OSX inside a G3, possible? Camilo Orozco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-21-2004 10:32 AM
