HD10 Lion Install Question
I'm currently on PTHD9 Native and on 10.6.5.
I'm thinking about moving to Lion. Not sure the best way to do so. I can put another drive in with Lion on it or I can update my current drive. Is there a best practice on this? Thanks in advance. Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Re: HD10 Lion Install Question
Apple recomends going to 10.6.8 first.
I did that, then cloned my OS drive, then did the Lion upgrade, then did the 10.7.2 combo update. It all went off without a hitch.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Did you clone just to have a backup? Also, I use time machine. Is that the same as cloning?
C
I always clone if I'm doing a major OS upgrade.
I did the same thing as ej and have had wonderful results with 10. There is an Mbox pro issue that is an easy workaround that Avid will fix at some point, other than that I really like the combo of 10 and lion so far.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
Pro Tools HD10 Native install to work on TDM | RDFiorentino | macOS | 3 | 07-07-2013 03:42 PM |
PT HD10 30 day trial question | soul | macOS | 8 | 01-26-2013 10:04 AM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
PT10, Lion OS, 003 RACK Install question | Psychonaut4 | macOS | 2 | 10-22-2011 03:25 AM |
